Mercedes-AMG F1 W10 EQ Power+
krizalid1001
krizalid1001
Re: Mercedes-AMG F1 W10 EQ Power+
W10's Low downforce Front & Rear wings
CLKGTR
CLKGTR
101
More pics of Mercedes F1 W10 low downforce aero package (open in a new tab for hi-res, Photo by Lars Baron/Getty Images)
Being pedantic, they're not low downforce aero packages, they're low drag aero packages.
But thanks for the pictures. =D> =D>
CLKGTR
CLKGTR
101
Just_a_fan wrote:
06 Sep 2019, 13:18
No problem, I love pedantic people :) But on the other side - is Monaco aero package then high drag package? Or high downforce, as high downforce is desirable there, just as low drag at Monza? I guess you wanna say to use the term which describes what they are trying to achieve with that particular package...
CLKGTR wrote:
06 Sep 2019, 13:22
Just_a_fan wrote:
06 Sep 2019, 13:18
Let's put it this way; At Monza you want to cut drag, but not cut downforce. At Monaco you want to gain downforce, but not drag.
Calling it high downforce or low drag is simply naming their desired effects.
foxmulder_ms
foxmulder_ms
It still has more wing than I expected. Let's see the speed :D
izzy
izzy
foxmulder_ms wrote:
06 Sep 2019, 15:17
at this point, it's Seb 216, Valtteri 213, Lewis 206. So it looks like a wet setup back-to-back with dry
CLKGTR wrote:
06 Sep 2019, 13:22
Just_a_fan wrote:
06 Sep 2019, 13:18
You could put a vertical board in place of the rear wing. It would very low (zero) downforce but no use at Monza as it's very high drag. If they wanted low downforce then they'd fit a smaller diffuser as well as a smaller frontal area rear wing.
I would say that at Monza they use a low drag setup, at Monaco they use a high downforce setup. As I said, it's being pedantic. :oops:
Sharnlarry
Sharnlarry
Has anyone seen the new sidepod shape Mercedes have been running. I haven’t got a picture but it’s pretty clear on the tv.
zibby43
zibby43
You can really see the shortened uppermost flap chord length here:
Lca1443
Lca1443
Would least negative and most negative CL work?
Really
Monaco is most negative CL
Monza is lowest CD
zibby43
zibby43
This is definitely new: *double* serration going on - serrated edge on the main plane and on the back of the flap.
via AMuS
Maritimer
Maritimer
19
Wonder how many hours go in to finishing parts like that, would surely be sanded and polished by hand.
izzy
izzy
zibby43 wrote:
06 Sep 2019, 23:34
via AMuS
https://pbs.twimg.com/media/EDx4hLxWwAY ... ame=medium
Serration city 😃
And the shroud as well, triple
Detail Brakes Today Qualy Monza
