McLaren MP4-29 Mercedes
emmepi27
emmepi27
141
Re: McLaren MP4-29 Mercedes
I think it's not new, but very interesting! It was under the butterfly's lower arm
Lucky
Lucky
157
trinidefender
trinidefender
318
From what I can see the differences are a (I haven't seen this change before although it doesn't mean it wasn't there) change in the profiling of diffuser. You can see where fresh carbon fibre has been laid down modifying the original design.
The shrouds around the front wheel brake disks appear to be different although this is probably a very track specific part.
As far as the small "diffuser wing" goes, I personally haven't seen it before but it seems others have. The difference between this and Williams design is that in the Williams car the wing seems to perform a bigger job. It appears larger and the diffuser is shaped differently allowing that wing to produce more downforce on the Williams. I wonder if it is connected to the rear wing end plates on the McLaren, as is on the Williams, and crucially if it has any role supporting the rear wing end plates.
scarbs
scarbs
393
The diffuser winglet has been on the car all season. It's a stand alone part that works below the mushroom suspension fairing. Williams have a wider winglet that acts like a beam wing, being both an aero part and supporting the top rear wing.
They modified the little Wings where the rear Crash Struture meets the Suspension Arms.
Singapore:
Spa:
matt21
86
I´ve not seen these strakes behind the wing support pylon anywhere else yet.
Edit: They belong to the wing endplate. Sorry for confusion
CjC
CjC
Boullier said on sky that there are upgrades from the front wing all the way to the rear wing all over the car this weekend. Have we seen them yet?
Just a fan's point of view
f1rules
f1rules
623
well they are testing with flowvis on the frontwing
gary123
Here is a better pic.
f1rules
f1rules
623
from mclaren facebook
f1rules
f1rules
623
you can see flowvish drops beeing sprayed over the car by the wind in this higher res picture
http://www.f1fanatic.co.uk/wp-content/u ... /magn1.jpg
and meassuring fronwing flex
Singapore 2014 - Firday (19.09.2014)
gary123
Formula1.com
