1) We are talking about the benefit of the exhaust flow, not 'essence' of the lap.Mandrake wrote: 1) But that is the essence of the lap. Everyone can drive in a straight line or through a corner with the foot buried down, but the crucial moments are the corners you have to brake/change speed for.
2) How do you know it's like that? Personal experience? ....
Disagree. It depends how the car is set up. The car might have been set up for an off-throttle balance, and have on-throttle understeer. Or it might have an on-throttle balance, and off-throttle oversteer.hardingfv32 wrote:1) As far as the exhaust layout goes, any imbalance that it causes will only take place while off throttle AND IN A TURN. This is not very much of the average F1 lap time. I am going to venture a number of less than 10% of the lap. It is rare that the majority of a turn is taken at part throttle.
The exhaust flow map might be consistant but track conditions/temp/grip/variations in turn in point/wind across the track etc etc etc all change that's why if the car is not really planted the car with behave differently and it's balance will change if the car attitude is upset due to one or more of those factors.hardingfv32 wrote:1) We are talking about the benefit of the exhaust flow, not 'essence' of the lap.Mandrake wrote: 1) But that is the essence of the lap. Everyone can drive in a straight line or through a corner with the foot buried down, but the crucial moments are the corners you have to brake/change speed for.
2) The exhaust flow 'map' is consistent over a lap and thus the benefit from that flow is consistent and predictable in relation to that 'map'. You do not require personal experience to come to this conclusion.
Brian
Well 'setup' might be a better term to use, as 'balance' is different for each driver.raymondu999 wrote: It depends how the car is set up. The car might have been set up for an off-throttle balance, and have on-throttle understeer. Or it might have an on-throttle balance, and off-throttle oversteer.
While everything you say is true, it has no relevance to this discussion of exhaust system layouts.eurocentric wrote:The exhaust flow map might be consistant but track conditions/temp/grip/variations in turn in point/wind across the track etc.....
That is what you said, I am saying that yes the map is predictable but everything else isn't so if anything else changes the cars balance can change and will. So the driver will not know how the cars balance will change.hardingfv32 wrote:
2) THERE IS NOTHING UNPREDICTABLE ABOUT THIS SETUP. The driver knows when he is off the throttle and he knows exactly how the car's balance will change.
Brian
I think the point he was trying to make was that the banning of the blown diffusers also makes them slower through the corners too.Lycoming wrote:tough to say, though having poor top speed is not that meaningful; Vettel was slowest through the traps in monza last year, but that didn't stop him from taking pole and the win.
