Hail22 wrote:You sir are brilliant thank you for posting it!
Will Red bull have enough time to make the appropriate changes the the duct? there is no way they can tape it as the heat generated inside the disc/drum would melt it/cause safety issues.
I can't see any sign of illegality on these brake ducts, but I think the problem is the way how wheel hub is ducted and vented...
11.4 Air ducts :
Air ducts around the front and rear brakes will be considered part of the braking system and
shall not protrude beyond :
‐ A plane parallel to the ground situated at a distance of 160mm above the horizontal
centre line of the wheel.
‐ A plane parallel to the ground situated at a distance of 160mm below the horizontal
‐ A vertical plane parallel to the inner face of the wheel rim and displaced from it by
120mm toward the car centre line.
Furthermore :
‐ When viewed from the side the ducts must not protrude forwards beyond a radius of
330mm from the centre of the wheel or backwards beyond a radius of 180mm from the
centre of the wheel.
‐ The ducts may not rotate with the wheels nor may they, or any of their mountings,
protrude axially beyond the outer face of the wheel fastener.
‐ No part of the car, other than those specifically defined in Articles 12.8.1 and 12.8.2,
may obscure any part of the wheel when viewed from the outside of the car towards the
car centre line along the axis of the wheel.
Maybe FIA consider wheel hub as part of brake ducts. And wheel hub is obviously located far outboard of "a vertical plane parallel to the inner face of the wheel rim and displaced from it by 120mm toward the car centre line."
