McLaren MP4-29 Mercedes
mikeerfol
68
Re: McLaren MP4-29 Mercedes
Del Boy wrote:Not a technical question but valid I think. Are the McLaren team making a great effort to hide the rear suspension when the car stops, in other words are all the pictures when it's running?
I think they said that it's not worth hiding it since either way the photographers will find a way to take a photo of it.
I was thinking about that too. Dragonfly suspension is fitting better.
acosmichippo
acosmichippo
Re: A closer look at McLaren's bufferfly suspension
Diesel wrote:
F1T wrote: The team's approach is far away from drag reduction. Instead, the elements are rather big with a cross section similar to a mushroom lying down on its side.
IMO, this is not correct. I believe they are just large rounded square in profile.
I thought so at first too, but if you look at the top left one, you can see that it isn't a square. hard to tell from these pics for sure, but people who have seen it in person have probably gotten good angles on it.
Coefficient
Coefficient
I think they are mushroom shaped as the post suggests but in the photo where they appear to be square they have a sensor array bolted to them to measure the oncoming air making the square. I feel this is evidenced by the fact that in the square configuration there is something visibly bolted to them which would make that illegal because they must be one piece under the regulations.
Avocado
Avocado
I'm in love. :oops:
f1rules
f1rules
635
Kevins debut from Danish tv, ill keep an eye out if more comes
http://www.bt.dk/motorsport/tv-se-kevin ... -i-f1-test
Holm86
261
f1rules wrote:Kevins debut from Danish tv, ill keep an eye out if more comes
Even though its just testing I'm pretty upbeat about him being the fastest so far :-)
Javert
miguelalvesreis wrote:Seems truly a quick car!
Yes we could think they have the best rear downforce :mrgreen:
Owen.C93
Owen.C93
191
No separation like last year's Ferrari.
mclaren_mircea
mclaren_mircea
Ben Edwards, BBC F1 commentator at Jerez
"I've been watching out on the track and it's fascinating. New boy Kevin Magnussen has taken over from Jenson Button in the McLaren and he looks very impressive indeed, like he's been doing it for years. It's hard to draw any conclusions about how the various cars behave because the drivers are really not pushing to the limit yet. From what I've seen so far, the Ferrari back end appears a little loose, which is not ideal in cars with so much torque. The Mercedes has a really good change of direction through the final chicane. The McLaren looks a little lazier but then it seems very stable in the fast corners. But of course none of these cars are in anything like the spec they will be by the first race.
smr
smr
A truly stunning car.
f1rules
f1rules
635
Avocado wrote:
I'm in love. :oops:
It's beautiful, from what we've seen until now pretty reliable and has decent base Speed. Can't ask for more after 3 Days of testing. ^^
Someone drive to Jerez and grad one of these rear Wishbones, we need to know the Shape.
Pup
Pup
50
turbof1 wrote:I was thinking about that too. Dragonfly suspension is fitting better.
Add another vote for the Dragonfly.
Owen.C93
Owen.C93
191
Wishbone flow vis showing that there is some upwash as can be seen by the line of accumilation above the bottom edge.
Rear wing flow vis.
