Scuderia Ferrari SF16-H
Frafer
Frafer
Re: Scuderia Ferrari SF16-H
Sevach wrote:Kimi overtake on Hamilton was an interesting moment, Kimi had a better exit and better acceleration early on in the straight and moved to what it looked like a standard overtake, then at some point his car just "died" and Hamilton started gaining ground.
Both cars had DRS i think (Hamilton less than 1s behind Massa).
i notice that too
https://twitter.com/RoboCoPJ/status/721602549418180608
henry
324
michl420 wrote:Also my understanding is to deliver 120 kw for about 60 seconds, they needed 7,2MJ per lap. Im also interested what is more effective for lap time, use the MGU-K before the braking zone short to generate with full power or just switch it off for a few seconds longer to charge the MGU-H energy?
The ES drain is 120kW minus the MGU-H output, probably in the range 40 to 50 kW. Making the drain 70 to 80 kW and the energy need 4.2 to 4.8 MJ. I would think this is achievable in qualification but not in the race.
As for which strategy is best for lap time I think you would need a full simulator to really know.
532
If from "the drain" you mean the energy store to the MGUK the answer is 4MJ, be it the race or qualifying.
henry
324
Yes, of course, you are right. I keep tripping over this. The max possible total energy to the MGU-K can be 4 plus whatever the MGU-H can deliver.
Thanks
Frafer
Frafer
Thanks
yep, but the K can charge the battery only 2MJ every lap, IMHO the big difference between PU stays in the H and how it works with the turbine/ice
Cloud981
Cloud981
Arrivabene
- When they developed the car they pushed for performance first reliability second
- Car proved to be reliable in China and was relief for a team that little problems are not present anymore
- Upgrades will come in gradual packages, they don't want to introduce big steps on new car rather want frequent smaller updates on aero side. In Sochi some small upgrades as well
- Engine will get upgraded as well, not saying when
- According to their calculations in qualifying they would be 1 tenth off Merc had everything gone as it should have without Kimi making a mistake in S3
giantfan10
giantfan10
27
Cloud981 wrote:Arrivabene
Funoanalistecnica on twitter is reporting a Pu upgrade for Ferrari in Sochi.
"They will arrive in the next GP important news regarding the PU. If everything goes as it should, the SF16-H will be closer to W07."
The speculation in the responses is that Ferrari will use the "reliability clause" in the rules to fix whatever has caused them to run their PU at reduced power.
giantfan10
giantfan10
27
Hamilton and Kimi had DRS ... Kimi used the slipstream to slingshot past Hamilton.... seconds later Hamilton got into Massas slipstream while Kimi was outside on his own...Hamilton then pulled ahead again until Kimi passed under braking with a better line into the corner...that may be the simple explanation
F1NAC
173
But that would mean new element or whole pu already in Russia. ?
armyk
armyk
It was said they have problems with ICE Turbo cooperation, not sure if they need to upgrade both or just one of them. Nevertheless they could use current engine for less demanding tracks where power doesn't play that big role.
giantfan10
giantfan10
27
armyk wrote:
F1NAC wrote:
giantfan10 wrote: Funoanalistecnica on twitter is reporting a Pu upgrade for Ferrari in Sochi.
Im not sure that using the reliability clause forces you to use a new engine .. hell im not even sure if you use a new engine or just fix the current one....i would assume that every usable engine would get the upgrade otherwise what would be the point?
ripper
ripper
39
As far as I know reliability clause is used to make changes, or let's say... "hidden upgrades", to the PU without using tokens, but those changes can be done on a new PU and can't be done on already used ones.
The point is that every upgrade that can be done without spending tokens is great advantage. Last year "reliability changes" made by Mercedes in Canada in an excellent example
giantfan10
giantfan10
27
ripper wrote:As far as I know reliability clause is used to make changes, or let's say... "hidden upgrades", to the PU without using tokens, but those changes can be done on a new PU and can't be done on already used ones.
I dont thinks thats correct. This is a snippet from an article about renaults reliability upgrades from last year... it appears that you can use that type of upgrade on a used engine.
