Gary Anderson described the system, or a system, last year when iirc Ferrari tried it but Kimi didn't like the effect on the steering feel. It was symmetrical.roon wrote: ↑Thu May 30, 2019 9:09 pmIs that the apex/full lock? Road camber visible under the RB front wing as well.
I'm interested to find out if the change in droop/travel is symmetric (dropping front ride height) or asymmetrical (dropping one side only, while raising or unaltering the other, causing roll).
1020hp is crazyzibby43 wrote: ↑Sat Jun 01, 2019 6:05 pmMercedes will debut their Spec 2 PU in Montreal.
Output is rumored to be at 1,020 horsepower. A significant increase in power for Mercedes.
"Mercedes will debut engine 2 that will be capable of more than 1,020 horsepower, with a significant increase in power, but without affecting the reliability"
- Motorsport (Italy), last paragraph
https://it.motorsport.com/f1/news/ferra ... h/4415276/
Holy cow! That output is in qualifying trim I assume and in race trim it's going to be significantly less?zibby43 wrote: ↑Sat Jun 01, 2019 6:05 pmMercedes will debut their Spec 2 PU in Montreal.
It's rare that we get a nugget of information like this. Not sure where the other manufacturers stack up numbers-wise, but I do think Ferrari had a slight edge on peak power output to start the season, so this could be a big step for Merc.damager21 wrote: ↑Sun Jun 02, 2019 5:10 am1020hp is crazyzibby43 wrote: ↑Sat Jun 01, 2019 6:05 pmMercedes will debut their Spec 2 PU in Montreal.
https://it.motorsport.com/f1/news/ferra ... h/4415276/Do we know where do they stack up against other engine manufacturers?
Correct. Some have speculated that race trim maps sacrifice roughly 30-40 horsepower.digitalrurouni wrote: ↑Sun Jun 02, 2019 6:17 amHoly cow! That output is in qualifying trim I assume and in race trim it's going to be significantly less?zibby43 wrote: ↑Sat Jun 01, 2019 6:05 pmMercedes will debut their Spec 2 PU in Montreal.
The way I've understood the quali-mode is that they run 1 lap with the wastegate open, and the turbine wheel de-coupled. So the MGU-H works as an electric supercharger. The advantage is less backpressure in the exhaust, and thats why you're able to produce a bit more horsepower. 30-40hp sounds pretty correct.digitalrurouni wrote: ↑Sun Jun 02, 2019 7:00 pmWow I was expecting more to be honest but that's really impressive.
That's an interesting idea but it doesn't seem very likely to me. There's the limit on fuel flow, 100kg/hr rate, that makes extra flow through the engine impossible or pointless, plus with the limit on battery deployment of 4MJ (33s) they'd have to take drive away from the mguK to do it and that can't be as efficient a way to use it. Also at top rpm they feed the K direct from the H and there's no limit on that, so I don't think they'd want to give it upHolm86 wrote: ↑Mon Jun 03, 2019 8:58 am
In race-mode you have to use the MGU-H to help charge the battery, hense more backpressure and the output of the engine drops a bit. Plus they don't use full electric boost to the MGU-K over the whole lap in racemode
I always wonder where the journalists get this information and how reliable it is.zibby43 wrote: ↑Sat Jun 01, 2019 6:05 pmMercedes will debut their Spec 2 PU in Montreal.
