Williams FW44
Re: Williams FW44
Andi76
Andi76
451
Re: Williams FW44
Moctecus wrote:
30 Jun 2022, 19:38
Another perspective (via The Race):
https://i.imgur.com/K8HDYFL.png
Edit: Old vs. new sidepod inlet
https://i.imgur.com/SmvA6UA.jpg
Quite impressive update. Will be interesting to see its influence on performance. Especially since this update means Mercedes will now be the one and only team sticking to a "micro/zeropod"-concept, what makes it obvious that this concept, like i said several times since February, is just the totally wrong way to go with the new regulary.
ogonek
ogonek
Re: Williams FW44
Controversial statement, problems due to budget constraints, not concepts.
SimonFW11b
SimonFW11b
Re: Williams FW44
It's a shame the car never raced with its side-pod vents open. I wonder if because flawed concept or legal challenge.
McMika98
McMika98
-24
Re: Williams FW44
SimonFW11b wrote:
01 Jul 2022, 07:33
Must have been a legal challenge or FIA clarification. Regardless there wasnt much going with that concept.
The new layout might lower the CG which will improve the setup and balance. Fingers crossed this is substantial
Tzk
Tzk
36
Re: Williams FW44
JordanMugen wrote:
01 Jul 2022, 00:51
I wonder why Williams decided on those larger radiator intakes in the first place, if they are now able to slim the intakes down significantly?
Maybe their tiny sidepods required it, because they needed a bit more force to push the air through the inside of the car? Now they got more space inside the pods, which should make it easier to guide the air through them.
MattWellsyWells
MattWellsyWells
Re: Williams FW44
Owen.C93 wrote:
30 Jun 2022, 19:51
There's a hint to how the airflow has changed when you look at the angle of the floor stay fixing between both cars.
https://pbs.twimg.com/media/FWhHSZXXwAA ... ame=medium
I wonder when the last time was a team fielded two cars that looked so different!
jagunx51
185
Re: Williams FW44
Moctecus wrote:
30 Jun 2022, 19:38
the inket looks like old A522
Re: Williams FW44
Intakes are more Ferrari-looking than original Alpine imo. They have the extended upper and lower leading edges.
Seems entire front of the sidepod is taking inspiration from the F1-75 - the outboard fence, the amount of undercut and the inlet shape.
Floor strakes' leading edges have similar curvature to those that Red Bull showed up with at the beginning of the season - a comparable angle of RB's floor leading edges isn't available due to their double bargeboard setup blocking that view. The ramped sidepod also is very RB V1. Will be interesting to see them continue development - more down an Alpine route perhaps? The floor edge detailing is also more similar to the RB than Ferrari. They have the guerney wavy flap (what else to call it) at a similar position to RB; perhaps this feature will not work particularly well with the outwash being generated significantly further forwards.. On the RB18 this feature aligns with the end of their undercut (in my view, with reason). The rearwards portion of their ramped sidepod seems to be tighter than the RB18 - perhaps because they're not using this part of the sidepod for large internal floor stays as RB are.
They've decanted the top two cars into their new sidepods
Don't suppose anyone has images of the t-tray? Would be cool if they had the double copied also.
CMSMJ1
CMSMJ1
Re: Williams FW44
It's a good looking car - made better.
Looking forwards to some wet running to see the flows and we might get some #6 vs #23 pics to compare.
The front of the tunnel looks ot be significantly revised too
IMPERATOR REX ANGLORUM
Re: Williams FW44
:mrgreen: =D>
Francesc
Francesc
50
Re: Williams FW44
That's one hell of update! :wtf: 8)
It will take a couple of races at least to understand it and extract the full potential.
Moctecus
154
Re: Williams FW44
Via Phillip Horton
Via Scarbs
GrizzleBoy
GrizzleBoy
Re: Williams FW44
Will be interesting to see top speed comparisons now of Merc powered cars now that all except Merc themselves have these apparently lower drag concepts.
carisi2k
Re: Williams FW44
A bit of a hybrid upgrade with some f1-75 and some rb18.
