2025 Scuderia Ferrari F1 Team
Andi76
Andi76
476
Re: 2025 Scuderia Ferrari F1 Team
10 Aug 2025, 18:48
Andi76 wrote:
10 Aug 2025, 18:47
It's been a while. Any insights to the problems that Ferrari had in Hungary?
Unfortunately, not really.
Seanspeed
Seanspeed
Xyz22 wrote:
10 Aug 2025, 12:48
So McLaren has already won 10 races this year which is the same amount of wins Ferrari collected from 2020 to 2024.
They will finish the year around 20 wins, probably. In order to arrive at 20 wins for Ferrari we need to go back to mid 2017.
These results highlight the difference between a Team that worked well with the goal of winning the world championship:
- Pushed for budget cap which allowed them to compete
- Invested huge amount of money in state of the start structures
- Hired top engineers and put great talents in leading positions
People thinking that Ferrari can produce a better car than McLaren are completely delusional.
I dont find stats like this all that useful. In season with 24 races per season, of course if you find yourself with the best car, you're going to rack up tons of wins in that given season that distort historic statistics.
Also, Ferrari very clearly work with the same goal as Mclaren. Many sports fans have this weird and mythological idea of 'competitors just wanted it more' which really isn't the case. Ferrari's issues this year are in fact quite specifically related to their desire to win the championship by making some bolder steps that would be needed to compete with Mclaren. It didn't work, but just sticking with last year's concept was clearly never going to be good enough. So they tried.
Mclaren simply have a better technical organization at the moment. There's nothing more complicated about it than that. It's an extremely hard thing to achieve, which is why even the previous superteam of Mercedes and the perennially topline Red Bull also cant match them.
I'm not massively optimistic for next year, but resets provide opportunity and unpredictability. Mercedes were major favorites for the 2022 rules reset and they ended up fumbling it quite badly and never really recovered even a couple seasons later.
Hope never dies.
Sergej
deadhead
82
Ok so they are just trying different methods to try and manage the problem.
This car is an absolute mess from a technical standpoint.
When was the last time they produced such a disaster? The illegal engine car? I’m not even sure if that was as bad as this.
WardenOfTheNorth
deadhead wrote:
11 Aug 2025, 14:10
2009 would be my suggestion. Until you realise that everyone else, except McLaren, is also struggling and maybe Ferrari aren't actually as bad as everyone keep suggesting.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
ScuderiaLeo
With the amount of Lico they have to do, maybe P4 would've been the end result no matter what... but I wonder why they didn't communicate the plan properly? It sounds like Leclerc was completely taken aback by the choices the team made. Did they not agree on a plan beforehand? Why did Leclerc think they were doing something else?
ScuderiaLeo wrote:
11 Aug 2025, 19:30
Leclerc is a driver. He is not seeing the information from the sensors and he cannot predict the plank wear. They have more information on the pit wall. It must be something that they think couldn't be managed with LICO. I don't think this is a situation where it's possible for the driver to make the call about how it will be managed.
Beware of T-Rex
Emag
Emag
137
To me it feels like McLaren is the exception of these regulations. They somehow found/understood something that has allowed them to maintain a development rate that none of the others could match. If you remove McLaren, even with all these plaguing issues, Ferrari would have been the leading force these last two years.
As for handling quirks, it seems like it’s just a symptom of these cars. Max was winning races by a landslide in 2023 and there were still races where he had bad things to say about the car. All drivers have complained about a weird feeling at some point with their respective cars, including McLaren drivers this year.
Ferrari has done a really great job all things considered. In my opinion, they have been bit in the a** this year because of their original floor concept. It inherently has a lot of potential, but unfortunately it doesn’t seem like it’s maintainable. SF25, when allowed to run without constraints, can be faster than the MCL39. The problem is that they seemingly haven’t managed to run it without constraints for a full race so far this season.
Developer of F1InsightsHub
deadhead
82
Emag wrote:
11 Aug 2025, 20:02
What about the RBR car form 2022, 2023, and 2024?
Emag
Emag
137
deadhead wrote:
11 Aug 2025, 20:48
Emag wrote:
11 Aug 2025, 20:02
Ferrari had a better car than RedBull in 2022. They failed to develop it as well and were also massively hindered by the mid season TD so RedBull ran with it. But it started out as a very close season.
2023, for some reason, both Mercedes and Ferrari dropped the ball hard and that flattered RedBull, who simply developed and refined their 2022 concept. The fact that Aston at the first half and then McLaren the second half were consistently 2nd force to RedBull tells you how badly Ferrari and Mercedes messed up.
And I don’t know why you mention 2024 as a good year for RedBull. They took advantage of a good start but that car was all over the place.
ScuderiaLeo
Article from Autoracer.
All teams “play” with tire pressures to protect skid block wear. In Budapest, there was an “inexplicable” collapse: data shows Leclerc was one second slower than the original plan.
The SF-25’s rear mechanical update was aimed at improving setup compromise, mainly by providing braking stability and better corner entry to a car overly unbalanced by an unpredictable rear end. The evolution of the rear layout, including wishbone geometry and updated internal components, delivered positive results relative to the set goals. In Hungary, pole position probably wouldn’t have been possible without the improved confidence the car can now give, with Leclerc already benefitting compared to a Lewis still in the learning phase with the previous platform. Managing floor wear will continue to force the team to seek compromises until the end of the year. The Budapest plan to keep at least one McLaren behind, taking advantage of a track layout unfavorable for overtaking, was working — until the final Hard tire set caused a collapse beyond expectations.
Reliable sources say a team typically increases pressures by up to 1.5 PSI to gain 1 mm of ride height in final stints, a practice that has become common since these cars’ downforce has grown exponentially since 2022. It’s a compromise, however, with negative effects on downforce and grip. With the final Hard set, Leclerc’s SF-25 went “out of window,” ending up one second slower than expected and losing 20 seconds in the final stint compared to simulations.
Ferrari has changed its dynamic behavior since 2024, and the floor now makes contact in unexpected areas: was the design mistake in not properly assessing how the 2025 suspension architecture would affect the floor? The SF-24 and SF-25 are aerodynamically related, but the same is not true for the chassis and suspension.
The thinking behind project 677 involved a deep mechanical redesign intended to unlock the famous aerodynamic potential — a technical choice that turned out to be “fatal.” The switch to a pull-rod front suspension in the final year of these regulations was meant to be a “calculated risk,” but it’s clear mistakes were made from the start of its development, as the car now strikes the plank with forces and in areas unforeseen by simulations, due to a lack of predictive correlation. Protecting the skid involves many measures beyond the well-known lift and coast, including raising tire pressures — something that we know for certain was done in Budapest, and which triggered the crippling of Leclerc’s No. 16 SF-25.
I cut out the first part of the article which was about Vasseur's renewal, but in summary it just said the team decided stability was important and Vasseur had the full backing of the drivers.
There are also some illustrations by Giuliana in the original article which I can't copy over due to their reprinting policy.
Sergej
ScuderiaLeo wrote:
12 Aug 2025, 08:14
Thanks for sharing for free a behind paywall article :mrgreen:
However, some things don't add up in my honest opinion. They are saying that the suspension update "was aimed at improving setup compromise, mainly by providing braking stability and better corner entry" and it delivered positive results, but what about the ride height ? for months they've been selling that the suspension update would have solved this fundamental issue which caused a double DSQ in China, see this article just after the Mugello test https://autoracer.it/ferrari-perche-la- ... unzionare/ "a revised layout in an attempt to better control the rear end and ground clearance, in a compromise between qualifying and the race" this is precisely what failed in Budapest, but apparently now this has never been a goal for the suspension update ? I don't understand.
Plus, they say there is a lack of predictive correlation, but I'm pretty sure that for months we've been hearing that they have a very strong correlation (also Vasseur and Leclerc said this after Bahrain tests), so I'm a bit confused where the truth stands. Finally this lack of correlation apparently produced a fundamental error also in the new pull-rod front suspension ? so they are saying Ferrari fuc*ed up both the rear and the front suspension ? I think it's the first time I read about a bug in the front suspension also, that has to be a spectacular failure by Maranello if true.
Emag
Emag
137
Is this the first time we get a reliable source mentioning the front suspension as the culprit for the plank issues? Don’t remember seeing it blamed before. I agree that the comments coming out about the issues have been very confusing lately. They try to maintain this cryptic facade as a team, but they’re doing it in a way where the drivers are saying different things from Vasseur all the time. Then you have these sources spitting out all sorts of theories.
I am fairly certain that the rear suspension upgrade was being labelled as a remedy for the plank wear issues when it was announced that it was under development. Now apparently it never was the actual rememedy and the problem is in fact the front suspension?
Don’t know what to believe at this point.
ScuderiaLeo
I assumed what they mean by that is in the process of changing the front suspension, they changed other parts too (their "since we're changing one thing we might as well change many things at the same time" thought process) and mistakes were made. Maybe they rushed development of the SF25. I don't think they mean the problem arose from the front suspension directly, that doesn't make much sense. The article doesn't make that clear though.
It sounds like the rear suspension was meant to help with the plank wear but since it didn't, they shifted the goalposts like that was never the intention.
I wonder how the canceled Baku floor fits in to all this.
Sergej
ScuderiaLeo wrote:
12 Aug 2025, 11:19
maybe they realized they didn't hit the targets with the suspension and they canceled the floor to save budget ? I think AR made an article about this, but it was (again) under paywall.
