Red Bull RB8 Renault
Rikhart
Rikhart
38
Re: Red Bull RB8 Renault
Rikhart wrote:Wait, there is a gap on the FW pylons? You can see bodywork through it on the second pic.
I mentioned this a bit ago, is it broken, or are those proper gaps?
raymondu999
If they were broken it would explain why the wing has such an aggressive stance
失败者找理由,成功者找方法
wjpbill
wjpbill
Interestingly Vettel has only completed 15 laps so far today in testing.
and the wing had those marks before it got "broken"
http://www.auto-motor-und-sport.de/bild ... ow_item=65
eurocentric
eurocentric
Scaled up section of the pylons
Th0R
Th0R
AMuS just reported RBR needs a gearbox change.
Rikhart
Rikhart
38
This is what I meant.
wjpbill
wjpbill
Wisdom wrote:Image
notice that nice big hole below the front suspension arm ?
I wonder where they are getting the airflow from to feed it and blow the diffuser?
Crucial_Xtreme
Crucial_Xtreme
404
see blue line
eurocentric
eurocentric
I have tried to bring out as much detail in PS as I could
I have noticed on another photo that there are yellow graphics on the strut which could make it look like it was showing the yellow graphic on the bodywork behind as if it was broken?
Fil
Hey guys, impulsive thought.. could the sidepod bridge near the exhaust be hollow, feeding sidepod air into the floor, or above the floor just inside the inside of the wheels? :-k
That sidepod bridge has bugged me since it was discovered.. there must be some reason for it to be shaped as it is, and fed into the floor as it is (beyond just aerodynamics).
Any post(s) made by this user are (semi-)educated opinion(s), based on random fact(s) blurred by the smudges of time.
Any fact(s) claimed by this user will be supplemented by a link to the original source of said fact(s).
Crucial_Xtreme
Crucial_Xtreme
404
Lots of flo-vis on turning vanes & splittle/t-tray
siskue2005
siskue2005
70
Fil wrote:Hey guys, impulsive thought.. could the sidepod bridge near the exhaust be hollow, feeding sidepod air into the floor, or above the floor just inside the inside of the wheels? :-k
There can't be any holes in the floor
Goran2812
Goran2812
27
Wow, Horner really thinks people are stupid...
Hope FIA does smth about them...
Visit my photo page! -> http://www.gorankphoto.com/formula1
boyracer94
boyracer94
If the pylons were cracked, then surely that would affect the neutral section of the wing as well as the flaps + endplates?
eurocentric
eurocentric
boyracer94 wrote:If the pylons were cracked, then surely that would affect the neutral section of the wing as well as the flaps + endplates?
Exactly and if only one was damaged why are both endplates at the same angle
