Mercedes AMG F1 W03
hardingfv32
hardingfv32
35
Re: Mercedes AMG F1 W03
skgoa wrote:Isn't there a senctence about "closed surface" as well?
I believe it is limited to surfaces 'in contact with the external air stream'. In this case the duct would be involved.
Brian
skwdenyer
skwdenyer
If the regulation specifies a minimum concave radius, how does that preclude a slot? Surely the local radius at the slot would be convex, I.e. the wing surface bending back in upon itself?
240
i think the wing elements are normal. I suspect the end plates are bypassing the air from the inner side as the drs lifts. The endplates are less restricted.
maybe some cross flow business is going on under there to stall the wing from underneath.
this is more like it:
i dont think it goes to the beam wing or that it's a signal pipe; which is possible still, but the stalling the beam wing is pretty difficult due to the low camber of its shape. Everything may be happening at the rear wing.
Ferraripilot
21
No gills on W03 in Australia so far
skgoa
skgoa
Well, its cold. ;)
Observations:
- Ted Kravitz is still believing in the wrong-way (i.e. back to front) version of the "f-duct".
- Rosberg's lap wasn't remarkable. (Then again, it was just a first sighter on a damp track.)
- I believe the heat shielding on the sidepods and upper wishbones has been slightly revised.
Crucial_Xtreme
Crucial_Xtreme
404
W03 Diffuser detail. Right click>view image
skgoa
skgoa
The camera just followed Schumacher for one lap:
- The front wing is flexing and is NOT being stalled.
- Schumacher is FAST.
- The W03 seems to handle very well for both drivers.
Edit after lap onboard Rosberg's car:
- Front wing still flexing, not stalling.
- He is fast, too. But Anthony Davidson said the car looked lighter than the Red Bulls did.
- He complained about understeer just now.
siskue2005
70
hardingfv32 wrote:
Raptor22 wrote:Let me understand this:The armchair aero guys are saying its more beneficial to stall a DRS activated wing, thereby shedding more downforce and creating a bigger front rear aero imbalance....?
If it is creating an imbalance during Qual then just close the DRS flap. How may corners benefit from a low drag setup? During the races it is not an issue and stalling the main wing would be a benefit.
Scrabs proposal is now off the table.
Brian
Lol i just love the way people dismiss Scrabs because their arm chair is better than scrab's personal contacts in the f1 paddock :lol: :lol:
skgoa
skgoa
Wow, we have made it down to childish ad hominem attacks... classy.
Pup: Actually, you can have two different kinds of blown flaps:
- Blowing in line with the surface, i.e. improving flow.
- Blowing straight out of the surface, i.e. forcing the flow to detach.
Pup
Pup
50
Oh dear, we're back to that. :?
siskue2005
70
skgoa wrote:The camera just followed Schumacher for one lap:
you wont be able to 'see' the stalling
just like we were not able to 'see' the f-duct stalling the rear wing
Pup
Pup
50
I'd think that if the wing is flexible enough that you could see it, unless it's so flexible that it does so even when stalled.
skgoa
skgoa
I am just quoting this for posterity. I don't think I need to make any more arguments.
atanatizante
126
Why I feel like kind of a deja-vu with 2009 season BGP001?
Jesus
MercAMGF1Fans
MercAMGF1Fans
James Allen was reporting from the pitlane, and what he said was VERY VERY promising..
I know, we all know it's too early, but Merc Have made a Substantial step forward, better than what they expected - just a one liner of what he said
