Tbh it looks as though Vettel is running the Barca race spec and Webber the Barca tested spec. No change to either that I can see - except maybe there is a slight dip after the exhaust slot on Vettel's car?
If the blasted tunnel is choking all the time, why don't they just eliminate the aftside "wall" of the tunnel? ie have the coanda ramp go down all the way until that last 50mm or so? Sort of a hybrid fashion between the bulge fairing and the V1 Sauber. Wouldn't that eliminate the chokepoint?
