Red Bull RB8 Renault
zztopless
zztopless
Re: Red Bull RB8 Renault
Crucial_Xtreme wrote:
RB7ate9 wrote:
If that's a pictures of the rear, then Red Bull should have a major change to the entire rear end (notice lack of tunnel/sidepod trailing slope). A-spec for Canada?
Yeppers. I'm looking at others and it definitely looks like on one car at least they're reverting back to launch spec
Or this is simply their low downforce spec that they have planned to run at circuits like Montreal and Monza all along? This was one of the few tracks that Red Bull were towards to top (by Red Bull standards anyway, Vettel was 7th fastest in Qual) of the speed traps last year...
RB7ate9
RB7ate9
I can believe that. They've had problems reconciling the wind-tunnel and real-life for the tunnel/coanda ramp, so any chance to reduce draw or stagnation points would be a bonus. Also, as it seems to be a more stable overall design, it could help Vettel and Webber(?) attack the corners.
raymondu999
Yes. The throttle sensitivity could be what they are after in this situation. Normally I would have just bought that - but Monaco is somewhere where you need a predictable car even more, with lots of confidence. If they saw fit to run the coanda exhaust in Monaco I don't see why they'll change it for here - except if they have decided to just forget the exhaust and knuckle down on the fundamental aerodynamics of the car.
失败者找理由,成功者找方法
Crucial_Xtreme
Crucial_Xtreme
404
As usual it looks like the RB is running quite a bit of rake. Amazing they are able to consistently do this while other teams are not able to follow suit.
siskue2005
70
it just shows that their car can flex at high speeds ? maybe?
anyway about the floor, why dont RBR jut make a small slit connecting their enclosed hole to the outside ....thus making it not enclosed but till has all the effect intended?? jut like the gills are legal due to slits connecting to exhaut opening.
anyone fancy this idea?
aral
aral
26
siskue2005 wrote:it just shows that their car can flex at high speeds ? maybe?
They can of course, but the slotted floor is only of benefit on slow circuits, and Montreal is a high speed circuit.
Crucial_Xtreme
Crucial_Xtreme
404
No, it's of benefit everywhere. China is a fast circuit and Red Bull used the slots there. It doesn't matter what circuit they're on, the slots help at all of them.
techF1LES
176
Craig Scarborough wrote:[Tyre squirt holes] are only worth 1-2 points of downforce, so they are useful, but not a big performance factor. With no fast turns, max. downforce is not a requirement in Montreal, so they are not advantageous here.
Cuky
65
I am not 100% sure, but I think problem was not only that hole was enclosed but that it was also on the part of the floor where it is forbidden. On the other hand, Ferrari and Sauber have their gills at the outer 50mm part of the floor.
Owen.C93
Owen.C93
177
I always thought the slots were a sign of the floor not doing what it's meant to. A floor without them indicates that they are not needed and would not bring an advantage if they did add them.
Crucial_Xtreme
Crucial_Xtreme
404
Sensors
N12ck
note how on webber's they are angled inwards, they are taking measurements off the flow from the inside of the tyre, most likely to test front wing :D
Budding F1 Engineer
Owen.C93
Owen.C93
177
They're angled to match the general direction of flow, just like McLaren do with their diffuser rake.
techF1LES
176
Red Bull has new winglet above the rear brake duct (note opening in the aerofoil):
techF1LES
176
Contour + Full HD video camera: http://contour.com/products/contour-plus
