Red Bull RB8 Renault
Re: Red Bull RB8 Renault
Obviously it's a component that would be very sensitive to surround airflow/heat/vibration, so not entirely surprising that it's okay in other installations.
Intego
According to AMuS it was the bearing of the rotor.
aral
aral
26
raymondu999 wrote:Lotus have 1 failure - Grosjean in Valencia. So 2 for Red Bull, 1 for Lotus.
Red Bull have had FOUR failures. Two for Vettel in races, one in practice. And one for Webber in race.
Lotus have also had failures in testing, as have Caterham.
raymondu999
Actually - the R30 Pirelli uses as test mule has had quite a fair share of failures. Have Renault been using that as an on-track dyno?
失败者找理由,成功者找方法
Crucial_Xtreme
Crucial_Xtreme
404
raymondu999 wrote:From the article, it sounds like basically they made modifications and fixes to the 2012-spec alternators (which, let's not forget - was reliable all the way from Melbourne to Valencia, and then Valencia to Monza) and they're fielding those. Not any special designs AFTER the failures.
Yes, it sounds to me like the other cars that use Renault engines used the new spec alternators in Austin. No problems from them so RBR feel like its the best way to go.
Intego
They more feel like they don't have 2011 specs any more ... :wink:
ziggy
ziggy
Hi. It was mentioned by Renault that the alternators suffered in low RPM corners
here:
http://www.autosport.com/news/report.php/id/102454
Ok, its logical, in the low RPM range less current is produced by the alternator.
http://www.mclarenelectronics.com/Produ ... e%20100Amp
Just look on the graph.
As I'm understanding the article, the alternator suffered because of overcurrent. Either Renault went over the limit with the new alternators or the car is simply demanding more current than the ALT produces. There were some talkings about Red bull using separate tanks for cooling fluids and oil, so they can pump the fluids all over the car, just where they want the additional weight. Those pumps could draw too much current in low RPM.
Cheers
Cam
45
Interesting thought ziggy and well done for thinking of a completely new cause for the problems - and for supplying backup data to go with it. If I knew more about that stuff and could verify it's plausible I'd +1. Does anyone know if this is conceivable?
― Socrates
Isn't it 3 for Red Bull now, Vettel=Valencia, Monza. Webber=USA
ziggy
ziggy
Cam wrote:Interesting thought ziggy and well done for thinking of a completely new cause for the problems - and for supplying backup data to go with it. If I knew more about that stuff and could verify it's plausible I'd +1. Does anyone know if this is conceivable?
Thanks.
Only Renault powered cars can run these separate tanks because of engine reliability or cooling issues and only Renault powered cars suffered from that failure, even Caterham. Sorry can't find the link right now.
Crucial_Xtreme
Crucial_Xtreme
404
New RW for the USGP
Joie de vivre
It's interesting how they quickly adapt upgrades by others (ie. sauber exhaust). Deffo less time than Merc's coanda exhaust.
McMrocks
McMrocks
32
fortunately the Brazilian track has not as much slow corners as the CotA
Intego
Joie de vivre wrote:It's interesting how they quickly adapt upgrades by others (ie. sauber exhaust). Deffo less time than Merc's coanda exhaust.
Ya, would be interesting to know their experience with the DRD from YDT. I wouldn't be surprised if they were the first (along with Sauber) to make it work properly.
raymondu999
McMrocks wrote:fortunately the Brazilian track has not as much slow corners as the CotA
What does this have to do with the RB8?
失败者找理由,成功者找方法
