Red Bull RB9 Renault
tony77g
tony77g
36
Re: Red Bull RB9 Renault
csponton wrote:I think the rear wing to Vettel and Webber is identical. Look at the pictures here: http://f1grandprix.motorionline.com/fot ... ABATO/p-2/
http://3.bp.blogspot.com/-HBf5hdooqBw/U ... ifiche.jpg
In FP3 wings were different
http://1.bp.blogspot.com/-it7GV_XzfZQ/U ... AA-1Tk.jpg
Dear friend, if you look carefully the picture you've posted, you can see that they are on Friday. The two cars have sensors on the sides of the air scop that are mounted only on Friday!
then you're wrong
Lheela
Lheela
Dear friend, if you look carefully the picture you've posted, you can see that they are on Friday. The two machines have sensors on the sides of the air scop that are mounted only on Friday!
then you're wrong
And actually, I would say the top pictures were taken in Korea. Once Vettel won with a helmet, he doesn't wear it again. Would surprise me to see him break his own "rule".
csponton
csponton
you're right Tony. thanks
Crucial_Xtreme
Crucial_Xtreme
404
Gary Anderson's analysis of the RB9 FW introduced in Korea, mainly the two new vertical strakes.
via AutoSport
tony77g
tony77g
36
the rear wing of the Red Bull compared to the other teams
i70q7m7ghw
i70q7m7ghw
49
Assuming you've all seen this?
http://www.bbc.co.uk/sport/0/formula1/24511950 (UK Only)
The heat-vision camera on the Red Bull shows front edge of the tea-tray glowing orange (hotter than the tyres). The "secret" is somehow Red Bull are able to run the front edge of the plank very low to the track without wearing it away to the point it becomes illegal.
Juzh
161
Diesel wrote:Assuming you've all seen this?
http://scarbsf1.com/blog1/2013/10/10/an ... -in-korea/
Interestingly they didn't have the heat signature at Suzuka.
If it is really scraping the plank on the ground, then they truly have geniuses at red bull. The materials used in the T-tray are pre-defined; not much you can do to influence wear, but apperently red bull still got it done.
gandharva
252
Webbers car was set up too low. This disappeared after FP1. Don't know how often this should be written again. :D
gandharva wrote:Webbers car was set up too low. This disappeared after FP1. Don't know how often this should be written again. :D
This is a false assumption. He had this every time when his IR camera in Singapore and Korea: during FP's, qualies and races. Every time. It didn't show up in Japan.
gandharva
252
tony77g wrote:the rear wing of the Red Bull compared to the other teams
http://www.zaslike.com/
For me this is a sign that RBR is already working towards 2014. They try to maximize innert downforce and diffusor efficiency towards the end of 2013. They can carry a lot of this development into 2014 season.
gandharva
252
No. The yellow signature was only visible in FP1. During race it was more like blue and therefore way colder. A bit of scraping always happens, so this area will never be completely grey.
This image came straight from the race in Korea:
It's hotter then the tyre.
gandharva
252
Probably from the beginning of the race. Due to high fuel load cars are much lower at the beginning of a race. I remain with my statement. All this t-tray kers etc... theories are crap and poor attempts to explain the strenght of this car. One can easily see on your picture that the heat is generated from scraping, as the biggest heat is seen on the bottom of the t-tray.
gandharva wrote:Probably from the beginning of the race. Due to high fuel load cars are much lower at the beginning of a race. I remain with my statement. All this T-tray kers etc... theories are crap and poor attempts to explain the strenght of this car.
There's video footage from the race right before the first safety car where it is exactly this hot. I'm btw not supporting any or other theory; it could very well be scraping the t-tray on the ground, while capacitors/resistors theories also sound plausible. I'm not dicussing that; all I know is that Webber, Vettel does not have the IR camera, runs the t-tray this hot all race-weekend long. Could be explained by having a very stiff suspension which minimizes the effect of fuel on ride height, allowing them to run low all the time. Also factor in the rake.
