McLaren MP4-29 Mercedes
bhall
bhall
244
Re: McLaren MP4-29 Mercedes
And I thank you. F1 is now a goldmine for good, old-fashioned, low-brow humor, because the cars look like dicks and sound like farts. This stuff writes itself.
frosty125 wrote:Could someone explain the sidepod cooling concept McLaren have gone for and the advantages of it. The angle of the radiators is very different to most of the other cars.
It's my understanding that sidepods are essentially pressurized systems in which air flow to cool the radiators is forced through them as a result of a pressure differential between the inlet and vent(s) of the sidepods. In other words, the forward motion of the car alone is not directly responsible for driving air through the radiators; rather, the forward motion of the car creates a pressure differential that is responsible for driving air through the radiators.
Because of that, designers have a bit of latitude when it comes to choosing a layout within. Radiators and intercoolers do not need to be positioned in such a way to make use of a ram-air effect. (Though, they can be.)
A relatively low-pressure system comes with a smaller drag penalty, because the inlets can be made relatively smaller. The trade-off is the need for a relatively larger radiator in order to provide the same cooling efficiency of of a higher pressure system with larger inlets. The benefit of the latter philosophy is overall tighter packaging, because it enables the use of a relatively smaller radiator.
(Relatively, relatively.)
And please accept this as a "Cooling for Dummies" explanation, as those are the only explanations I'm qualified to offer.
Jenson Button on AMuS:
http://www.auto-motor-und-sport.de/form ... 21310.html
So the Updates in Sepang help with the Car Balance, not pure Downforce. Once they have a well balanced Car they will add Downforce.
f1rules
f1rules
635
This update looks a bit inspired by the update they brought in 2012, during the spanish gp, where they raised the nose for allowing more air under. Will be interesting to see how much rear df it will ad. If it will enable them to run more frontwing angle or its just there to dial out the understeer/stabalize the rear in high speed. No matter a nice upgrade.
Pup
Pup
50
Great shot of the rear suspension...
The rear profile of the mushrooms looks almost semicircular in this shot.
gary123
Very elaborate pylon design.
heimana
heimana
gary123
heimana wrote:
the FW is new?
to me it seems the same.
Didn't see the complete Front Wing but from that Picture it looks the Same as Melbourne.
And from tha Angle of the Last Picture the Nose looks better already. 8)
Rikhart wrote:Isn´t that nose very similar to the caterham one? A triangular leading edge, then "the dong" hanging out from it. At least in concept it appears pretty much the same.
I'm in the "copied from STR" camp.
Avocado
Avocado
Esso logo.
SidSidney
SidSidney
So still essentially the same company:- Esso = Ess Ohh = S.O. = Standard Oil. Esso + Exxon + Mobil 1 = ExxonMobil Inc. Interestingly Esso used to also be Esso in the USA back when it was Rockefeller running the shop, but was forced to become Exxon due to the original anti-trust laws in the early 1900s.
Reason: removed image tags; images in quotes should only be a link to the picture.
This signature is encrypted to avoid complaints, but it makes me laugh out loud:-
16S75 13E7K 41C53 7CT23 14O5O 67R32 76175 90B67 L4L42 41O63 72W56 98M10 52E87
CjC
CjC
Do we think that the front nose solution seen in Malaysia is the one which failed the initial crash test pre-season? And the previous one we've seen in Aus was a 'safe' solution?
Just a fan's point of view*
Holm86
261
CjC wrote:Do we think that the front nose solution seen in Malaysia is the one which failed the initial crash test pre-season? And the previous one we've seen in Aus was a 'safe' solution?
Don't think so. I think the one that was on at launch was the one that failed. People in here seems to think that if the nose fails a crash test a complete redesign is needed. Its not.
This is probably just a planned update. And I would not be surprised if we see several other noses during the season. From every team almost.
