McLaren MP4-29 Mercedes
bauc
35
Re: McLaren MP4-29 Mercedes
stefan_ wrote:
oT v1 wrote:disappointed they dropped the butterflies, one of the more exciting bodywork developments this year. Also shows it was a mistake, what were they doing with it before? especially if correlation is good in the wind tunnel. (hopefully it stays on for the next races though)
Hold on, maybe they just want some track time with a normal suspension to compare the two. It doesn't mean that the butterfly is a disaster.
We'll see in China if it stays or maybe it will be used only on certain tracks.
WOW, again you guys are jumping to conclusions right away.......Hold on a sec, maybe they are just testing low downforce spec set up for the races like SPA & Monza???!!!!
Thanks
smr
smr
I think Stefan is right... they are probably just A/B'ing the butterfly suspension with and without to see how the car works without and which is more efficient. It's great that they are testing on a track on which they've just gone flat out on as it gives them such good data to work with and comparison data.
Crucial_Xtreme
Crucial_Xtreme
404
smr wrote:I think Stefan is right... they are probably just A/B'ing the butterfly suspension with and without to see how the car works without and which is more efficient. It's great that they are testing on a track on which they've just gone flat out on as it gives them such good data to work with and comparison data.
Not just A/B'ing but even testing just one of the butterflies.
via Sutton
mikeerfol
68
Everyone was slower than Quali, but if you look at FP3 results (similar conditions to today) Kevin was 2 tenths faster than FP3.
Duke
Expect they are testing it without for the high speed circuits where it isn't needed.
flyboy2160
flyboy2160
84
Cool it with calling each other morons.
RagingBullx
RagingBullx
I know it's been mentioned before but why do the red bull and mercedes have so much more rake than mclaren, and do they have one of those trick FRIC suspension systems yet?
Everybody has interlinked suspension, everybody has had it for a long while.
How trick it is, is entirely up to the team in question.
Emerson.F
Emerson.F
Supporting: Ham/Alo/Kimi/Ros/Seb/Hulk/Ric/Mag
gray41
Suspension failure in todays test for McLaren.
http://www1.skysports.com/f1/news/12430 ... -in-tweets
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
Bahrain Day 2 Test Afternoon Session with Full Butterfly Suspension:
Jef Patat
Jef Patat
gray41 wrote:Suspension failure in todays test for McLaren.
Indeed, broken rod. A bit easier to find between the rest:
http://www.scribblelive.com/Event/Bahra ... /112778855
outer_bongolia
http://formula1.com/wi/enlarge/sutton/2 ... 8ap298.jpg
via Sutton
If this works, they will then need to optimize the hot air outlets as well. Heck, if the half -or none- butterfly suspension looks good with the outlets where they are, Macca will be able to find even more speed by optimizing the shape of the rear end.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
akshat21
akshat21
The image is captioned front wing failure
flyboy2160
flyboy2160
84
I moved a general question about Mercedes engines to the Engine Ying Yang Thread.
