Scuderia Ferrari SF16-H
Big Mangalhit
27
Re: Scuderia Ferrari SF16-H
The side to side comparisons clearly show a longer wheelbase probably has a consequence of that slim rear. Very like the size zero (tm) from McLaren, no?
Silent Storm
102
The ones with the least to say always want to be heard the most…
Juzh
161
giantfan10 wrote:
pictures are labeled backwards
Can confirm.
Rear end is noticeably slimmer. Could be at expense of longer wheelbase though as previously suggested. Also, is it just me or do the sidepod openings actually look bigger on the 16H?
superdowg316
What are those new vents beside the drivers enclosure? Is it some form of cooling vent to the engine?
My goodness has that rear bodywork gotten slimmer. Seems to be a running trend so far with the Williams and Merc. Must be something back there that the teams have found to get an advantage.
Friendship with Honda ended, Renault is my new (and more reliable) friend.
Gilles27Kimi7
25
It seems that the front cameras are higher than in the SF15T
a1b2i3r45
The nose structure, top panel on the nose and the tight rear end looks similar to last years Mclaren and the RB :lol: :lol:
GPR-A duplicate2
64
Phew....
Ferrari has copied the suspension arrangements from Merc.
Silent Storm
102
I think wheelbase is same as last year.. If anything they might be a tad shorter 10-15mm maybe
bonjon1979
30
Silent Storm wrote:I think wheelbase is same as last year.. If anything they might be a tad shorter 10-15mm maybe
How can you tell this?
ollandos
looks like mclaren or its only my view?
Silent Storm
102
https://twitter.com/eligp/status/700676220560785408 Both images are not at same scale but if they were I don't think there would be much difference between both cars.
Yurasyk
bonjon1979 wrote:How can you tell this?
Look here
http://www.f1technical.net/forum/viewto ... 42#p619242
Gents, I'll repeat myself: no posts concerning the livery here!
Whodeany13
The rear on the SF16-H is gorgeous, that's a size zero if ever I saw it :D
I hope F1 is in Bernie's will!
