Scuderia Ferrari SF16-H
domh245
domh245
30
Re: Scuderia Ferrari SF16-H
The rules call for an average deceleration of 2.5g over the first 150mm of the structure, not exceeding 10g in the first 100mm, and not exceeding 20g before 200mm. I would guess then that the bulge of the nose is shaped as it is to meet the requirement for a low nose whilst being just enough to bring the average deceleration up to what it needs to be. As you say, the rest of the nose section looks a lot more solid, so I guess that the stub doesn't actually need to provide much in the way of deceleration if they can get it from the more solid part with the advantage of reducing weight.
(O/T - am I right in assuming that the front wing itself isn't attached during the crash but the pylons are? This image suggests so)
If they can achieve the required decelerations without the buldge itself, they could make buldge out of paper mache' for all they care...
240
It's just to meet the geometrical regulations and even though it's thin i believe it still plays a structural part in the crash tests.
Manfer
Manfer
So they can go shorter if they increase the thickness. Maybe they have that length to help with the aerodynamics around the neutral part of the wing.
Fer.Fan
Fer.Fan
Cloud981
Cloud981
AMuS: New turbo anticipated for Canada will cost 2 token. Aim: generating more electrical power through MGU-H without loss of power in engine.
Cloud981
Cloud981
According to Bild Ferrari has new sidepods and diffuser in Barcelona. Apart from improved aero, parts also weigh less.
F1NAC
173
asymmetric front brake housing
They trying to reduce the heat to the left front tyre.
flickerf1
flickerf1
The Wicked + The Divine.
f1316
88
flickerf1 wrote:Is this Monkey Seat new?
https://twitter.com/albertfabrega/statu ... 9625800704
Looks like the same old monkey seat to me, although you may be right that they've not run it on this year's car yet.
f300v10
f300v10
185
It's different than last years model:
Image from @Albrodpul
atlantis
atlantis
21
giantfan10
giantfan10
27
Was quoted somewhere that they were bringing new sidepods and there is also a new rear wing they didnt run in sochi that they may run here... diffuser is also said to be new.
Sidepods are said to weigh less than the previous version
