Mercedes-AMG F1 W10 EQ Power+
TAG
Re: Mercedes-AMG F1 W10 EQ Power+
:lol: they looked hollow! that's why I get for critical observation before my first cup of coffee!
माकडाच्या हाती कोलीत
adrianjordan
Interesting sculpting of the upper fairing on the Halo at either side... Presumably to help condition airflow.
Favourite team: McLaren
Vasconia
Nose is(seems) narrower, I guess its to improve the airflow. Sidepods and all this area is very developed, which is not a surprise. Too early to say that the new rear can help to improve tyre managment without damaging the one lap performance.
mantikos
mantikos
35
TAG wrote:
13 Feb 2019, 15:25
https://abload.de/img/45bkp8.jpg
Those two big number "11" ducts at the front seem to be there to do a hell of a lot more than cool the driver. That's looking very interesting indeed. It's not on the release car pictures, but it's front and center on the car they put on track to do filming with.
You mean the S duct which is a carryover from last year by the 77 not 11 number decal
dans79
267
Merc is definitely doing something weird to me.
The front wing looks very neutral, not in wash or out wash.
The entire tea tray area looks like a giant snow covered in winglets and vortex generators.
In the pre-launch renders they had this interesting looking wing/appendage connected to the side pod, and it showed up on the actual car.
It seems like it would be very draggy, but it appears like Merc wants inwash at the front wing so the can use the bat wing, snow plow, barge boards and turning veigns to work the air to death. I can't see how they would get that much flow turned around the side pods.
Jokingly it seems like they just moved the out wash effect from the front wing, to just in front of the sidepods.
197 104 103 7
mantikos
mantikos
35
dans79 wrote:
13 Feb 2019, 15:59
https://i.ibb.co/VMGvrhW/2.jpg
https://i.ibb.co/z8QBKC6/1.jpg
https://i.ibb.co/6t4T58t/4.jpg
I'm sorry but you've contradicted yourself and there is no way you can tell that the car is draggy without cfd or windtunnel
desl
desl
36
dans79
267
mantikos wrote:
13 Feb 2019, 16:04
I said looks! Something can look one way, but not actually function that way.
mantikos wrote:
13 Feb 2019, 16:04
](*,) no crap man, it's called an opinion.
197 104 103 7
dren
226
It looks like the front push rod connection is pushed out from the hub
Honda!
F1Krof
94
Kind of this area looks raised? Or it is just an illusion?
Btw, the livery resounds to that of W01, I just hope it doesn't drive like it.
Wroom wroom
dans79
267
mantikos wrote:
13 Feb 2019, 16:27
So it looks a certain way to you, but you also know it functions a different way, and you state both :wtf:
your head would be one confusing place to live
:lol:
You look at the wing, and then you look at everything behind it, and try to piece together how everything works as a concept. Components don't work in isolation.
197 104 103 7
Godius
186
JRodrigues wrote:
13 Feb 2019, 12:43
TimmTurbo wrote:
13 Feb 2019, 12:42
JRodrigues wrote:
13 Feb 2019, 12:40
3 supports for each mirror?
I see only two, the outboard one is sculped for airflow
I reckon that the black line which you have marked in green is the seam from the headrest area.
GPR-A
37
Sorry for the crude work (obviously not an expert). Took an image from the following link and done some silly work.
https://pbs.twimg.com/media/DzSjJisX4AAx0CZ.jpg
A comparison of RB15 Vs W10 rear. RB15 have packaged the PU ancillaries in a vertical fashion, whereas W10 has gone slightly horizontal, but seems like more compact. Look at the empty floor area and open space inside the rear wing. There is more space open on W10 than RB15 (may be because RB15 has relatively shorter wheel base?).
