Mercedes-AMG F1 W10 EQ Power+
zibby43
zibby43
669
Re: Mercedes-AMG F1 W10 EQ Power+
dans79 wrote:
Mon Dec 02, 2019 5:57 pm
LM10 wrote:
Mon Dec 02, 2019 5:41 pm
Sharnlarry wrote:
Mon Dec 02, 2019 5:38 pm
It was indeed a new 2020 spec engine
There was one live-ticker writing that some teams in the paddock claimed Bottas' Mercedes was running a 2020 spec test engine with 2 tenths a lap advantage.
ted kravitz mentioned something on air during one of the sessions this weekend, and i assume a lot of other people just copied or paraphrased what he said.
I don't remember exactly what he said, but it was based on a conversation he had with Andy Cowell. I believe it was something along the lines of Bottas was using an engine that used some concepts similar to the 2020 spec, and that would be worth up to 2 tenths a lap.
My interpretation of this, would be that they ran a 2019 spec 3 engine with 2020 spec 1 software/mappings. Running an actual 2020 spec motor is unlikely in my opinion as it would most likely require different packaging and cooling, since Mercedes is rumored to be making a big change.
I agree with most of this, but I'd add that they likely did use a few new hardware components (testing items to be further refined for 2020) that were new for this "Spec 4." They ended up using 2 new ICE units over the weekend, as the first suffered a pneumatic leak. The second ICE unit completed FP3, qualifying, and the race.
In sum, we can call these final iterations '19 Spec 4 engines because of different hardware/software configurations compared to previous Spec 3s.
But I agree, to call it a 2020 PU would be a step too far. Especially as there is an architecture change coming for 2020.
Wass85
Wass85
-19
Has anyone got any top speed data for Hamilton and Bottas for the race?
dans79
dans79
395
Wass85 wrote:
Mon Dec 02, 2019 10:42 pm
Max Speeds:
https://www.fia.com/file/111691/download
Best Sector Times:
https://www.fia.com/file/111690/download
173 101 99 7
Wass85
Wass85
-19
dans79 wrote:
Mon Dec 02, 2019 10:46 pm
Max Speeds:
Best Sector Times:
Cheers, doesn't look all that impressive to say Bottas had a new engine.
dans79
dans79
395
Wass85 wrote:
Mon Dec 02, 2019 10:49 pm
Max Speeds:
Best Sector Times:
Since the team knew well before the weekend that Bottas was going to start at the back, his car was most likely set up differently because he was going to spend a lot more of the race in dirty air. Bottas would most likely have altered his driving style to preserve his tires as well. Both reasons would mask any PU advantage he had.
173 101 99 7
Wass85
Wass85
-19
dans79 wrote:
Mon Dec 02, 2019 10:56 pm
Max Speeds:
Best Sector Times:
If you know that is the case then you set up the car for overtaking, i.e. Run less downforce.
dans79
dans79
395
Wass85 wrote:
Mon Dec 02, 2019 11:07 pm
That would only work at some place like Monza, where you have almost no slow speed sections. At other tracks more factors must be taken into consideration.
At some place like Yas Marina, You will need to run more front df because you want to gain on the cars in front or at least not loose a substantial amount of ground to them through sector 3. Depending on how much front wing is added you might need to add more rear df to balance out the car.
If you are going to be in dirty air a lot, you might also decide to open up the brake ducts to keep the brake temps under control. You might also open up the sidepod inlets and outlets for better cooling of the PU. How many times have we heard the merc pit wall on the radio about tire or brake temps this season?
173 101 99 7
Max Speeds:
Best Sector Times:
Looks like some drivers benefited from a serious tow in the speed trap figures. Max, for example.
The speed figures always seem a little bit odd to me for this reason. Get the right position relative to another car and you can be several km/h faster than anyone else.
LM10
LM10
132
Just_a_fan wrote:
Mon Dec 02, 2019 11:42 pm
Max Speeds:
Best Sector Times:
Max had open DRS and double slip stream.
GPR-A
LM10 wrote:
Tue Dec 03, 2019 12:51 am
Max Speeds:
Best Sector Times:
Isn't it pointless to look at speed trap in race? Different tyre life, fuel (some carry more than others), engine modes and toe skews the picture.
dans79
dans79
395
GPR -A wrote:
Tue Dec 03, 2019 2:37 am
Because we are bggers, we can't be choosers.
173 101 99 7
GPR-A
dans79 wrote:
Tue Dec 03, 2019 2:53 am
:lol: :lol: :lol:
Alight the Speculation Topic for the W11 is opened--->viewtopic.php?f=12&t=28632
One last appreciation of how beautiful the packaging is.
AMuS
zibby43
zibby43
669
MtthsMlw wrote:
Wed Dec 04, 2019 5:46 pm
https://imgr1.auto-motor-und-sport.de/G ... 653850.jpg
AMuS
Well said. Came here to express a similar sentiment.
