Ferrari F138
Bomber_Pilot
Re: Ferrari F138
amouzouris wrote:FP2: Finally the new exhaust and flow conditioners on Alonso's car as well
And now Massa is running with the old configuration (old fw, old exhaust and no flow conditioners)
amouzouris
105
Re: Ferrari F138
yes i noticed that a bit after i posted...maybe they brought only one set of the upgraded exhaust?? i think its unlikely but we'll find out
FrukostScones
163
Re: Ferrari F138
I luv this years Ferrari's design. very detailed, very beautiful.
Re: Ferrari F138
Alonso did the best time with all the upgrades plugged in, which is good news, exhaust, sidepod blade, nose and FW.
Bomber_Pilot
Re: Ferrari F138
They ran the updates through the entire FP2, which indicates that they will keep them for the rest of the weekend. But they seem to still have quite a lot of work to do, because even though Alonso set the fastest time, the car looked like quite a handfull.
shelly
shelly
136
Re: Ferrari F138
No shark mouth? I have the impression that the shark mouth is used just at high downforce circuits - but I do not remember if it was there in monaco.
twitter: @armchair_aero
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
Love these flo-vis shots =D>
via Sutton
KennyBama
Re: Ferrari F138
Kiril Varbanov
147
Re: Ferrari F138
@Crucial_Xtreme - awesome shots, looked like a busy FP for Scuderia. I also noticed that the turning vane under the nose has turned into two element instead of three and the usual (already) Kiel-probe rake.
A comment and a shot from fellow blogger Matt Somers:
Notice the added brake duct inlets instead of their usual Scoopless efforts
sucof
Re: Ferrari F138
Pirelli might use a solution favoring Ferrari: http://www.autosport.com/news/report.php/id/107926
Though I wonder if the new glue instead of the kevlar belt, would change the working temperature range or not?? But I guess it surely will not alter it like the kevlar belt, 10 degrees. So this is good news for Ferrari! Also, does anybody knows what was the opinions of the different teams regarding to the FP1 new tyre test?
Huntresa
Huntresa
Re: Ferrari F138
I hope they run all this in qual today, to rly show they made good progress.
Re: Ferrari F138
Canda 2013 - Friday (07.06.2013)
Canada 2013 - Saturday (08.06.2013)
via Tobias Grüner
PABLOEING
PABLOEING
Re: Ferrari F138
Alonso said that all updates work very well......good news
Diosfenix
Diosfenix
Re: Ferrari F138
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
Scarbs take on the new F138 FW:
The front wing is the most interesting part. The cascade winglet mounted to the wing's endplate has completely changed. Rather than being a horizontal wing, the element is now curved such that it meets the wing in an 'r' shape.
The revised cascade wing will probably create downforce, but the change is more likely to be about modifying the way the winglet bends the airflow around the outside of the front tyre. The new outer vertical section of the winglet will be quite effective at turning the airflow.
Link
He also says he's told the pelican noses actually do add downforce even if their design is counterintuitive at first sight, as it appears they would add lift not downforce.
