Ferrari F138
nhojekim
nhojekim
Re: Ferrari F138
astracrazy wrote:
whats going on along the edge of the main pane (against the endplate) it slopes down instead of up? haven't seen a shot before to notice it
I don't know when did they introduced that, but definitely not knew.
sucof
38
Re: Ferrari F138
Isn't this a new air cooling exit with grills just after the exhaust exit? Instead of the current "one hole" design?
Or just a silly light reflection?
aral
aral
26
Re: Ferrari F138
Coarse cf weave.
trinidefender
trinidefender
318
Re: Ferrari F138
If you are talking about the front wing then the reasoning behind that is simple. All the different planes work together as one big wing with the flow from each one going on to the next plane and stopping it from stalling. If you look at the rear wing the leading edge of the profile is actually pointing down, not up (if looking at the wing from the front looking back). It is the same concept with the front wing. By pointing the first wing element down then it pushes more airflow under the wing which means that later elements can be run at greater angles without stalling and worked harder to produce downforce or change the direction of airflow
Re: Ferrari F138
Hungary 2013 - Thursday (25.07.2013)
Hail22
144
Re: Ferrari F138
Gilles Villeneuve
Re: Ferrari F138
enz0
enz0
Re: Ferrari F138
Interesting how this one doesn't have the exhaust part of the sidepod. I hope it's something new and interesting
in that area.
astracrazy
astracrazy
31
Re: Ferrari F138
in that area.
all it shows is that the sidepod is made up of multiple parts and in that photo most parts are missing
enz0
enz0
Re: Ferrari F138
astracrazy wrote:
in that area.
Exactly why it might have changed, ferrari showed the tips of those a few weeks back but now it might be hidden for now
Re: Ferrari F138
Owen.C93
Owen.C93
191
Re: Ferrari F138
Getting back to MP4-25 cascades.
tony77g
tony77g
36
Re: Ferrari F138
Changes to the Helmholtz resonance chambers
for details read here: http://www.f1sport.it/2013/07/25/f1-la- ... helmholtz/
Dream Theater
22
Re: Ferrari F138
Lotus-like diffuser for Ferrari in Hungary, source: http://www.omnicorse.it/magazine/29553/ ... tile-lotus
emmepi27
emmepi27
141
Re: Ferrari F138
Two different exhaust's configuration at Hungaroring.
I'm waiting for a lot of images of new diffuser [-o<
