Ferrari F2012
ema00
ema00
Re: Ferrari F2012
does it mean that the yesterday "new" configuration doesn't work? I hope not, it'll be another big fail
amouzouris
105
Re: Ferrari F2012
ema00 wrote:does it mean that the yesterday "new" configuration doesn't work? I hope not, it'll be another big fail
yesterday's configuration wasn't the real update...it wouldn't be legal...
it was just to test the effect the update will have...
ema00
ema00
Re: Ferrari F2012
thank you :wink:
new photo:
nemoqueverto
nemoqueverto
Re: Ferrari F2012
I will not contenplate what was the time to prepare the update nor the effect of it. I just tell You what I see. From the pictures posted above I can see that today car configuration is tighter around the gearbox and a bit of engine cover. The bodywork ist more like a skin there. Yesterday Alonso had a car more focused towards the exhaust configuration - Massa tests today in the morning more traditional aproach but with more attention to detail. Tighter coke bottle shape is more effective isn't it? Well if both work well then we will see a combination of the two - I guess.
E=mc²
.poz
.poz
Re: Ferrari F2012
amouzouris wrote:yesterday's configuration wasn't the real update...it wouldn't be legal... it was just to test the effect the update will have...
why not ? I don't see much difference between Ferrari exhaust and previous Sauber one
I mean, we don't have a clear picture of Ferrari solution: if the exhaust exit point 10 degrees upward and the "tongue" is outside the cone defined by the point 5.8.4 of Technical Regulations is should be legal.
amouzouris
105
Re: Ferrari F2012
http://motorsport.nextgen-auto.com/gall ... pr/192.jpg
the 'tongue' is attached to the exhaust so it makes it part of it...and even if it is legal...yesterday's work was just patch up work.....u can't really expect ferrari to have such an incomplete upgrade...
motobaleno
Re: Ferrari F2012
The problem is that yesterday ferrari "tongue" was an integral part of the exhaust exit obtained simply bending down and cutting the tube and so I think that it was not legal but it is only a formal problem: it is rather easy to make legal such a solution if they want to use it on race
.poz
.poz
Re: Ferrari F2012
amouzouris wrote: the 'tongue' is attached to the exhaust so it makes it part of it...and even if it is legal...yesterday's work was just patch up work.....u can't really expect ferrari to have such an incomplete upgrade...
Bodywork(FIA official definition):
All entirely sprung parts of the car in contact with the external air stream, except cameras, camera housings and the parts definitely associated with the mechanical functioning of the engine, transmission and running gear. Airboxes, radiators and engine exhausts are considered to be part of the bodywork.
But i agree that was an experimental solution. BTW i read that Ferrari is using some sort of flexible junctions to be able to move exhaust exit for test and those junctions are illegal in a race
.poz
.poz
Re: Ferrari F2012
motobaleno wrote: The problem is that yesterday ferrari "tongue" was an integral part of the exhaust exit obtained simply bending down and cutting the tube and so I think that it was not legal but it is only a formal problem: it is rather easy to make legal such a solution if they want to use it on race
I agree. Let the tongue start 1 mm before the exit and it should be legal
Postmoe
Re: Ferrari F2012
Yes, you went completely FIA here.
Curious way to regulate, though.
ParanoiD
Re: Ferrari F2012
looking at the bodywork around the exhaust exit. Could it be that they try to divert the airflow using air exiting from radiator (internal) instead?
Ay Carumba!
Mr.G
34
Re: Ferrari F2012
I think, what we saw yesterday was legal and look's like this (sorry I have only paintbrush in this PC). It's easy to mount (even diferent versions) and esasy to rotate around the exhaust pipe to change/find the right position.
Teechnical
Re: Ferrari F2012
Recent comments and pictures don't really predict that the new upgrades will bring a change to the car which will jump them up to the podium. Btw will the acer ducts still be present in the new exhaust upgrade? Or will we ditch them to go to a Mclaren or a Sauber style solution.
"We have a new toy" - Fernando Alonso.
f300v10
f300v10
185
Re: Ferrari F2012
Teechnical wrote:Recent comments and pictures don't really predict that the new upgrades will bring a change to the car which will jump them up to the podium. Btw will the acer ducts still be present in the new exhaust upgrade? Or will we ditch them to go to a Mclaren or a Sauber style solution.
The latest rumor is Ferrari will run their new sidepod/exhaust setup tomorrow, supposedly without the much discussed Acer ducts.
Chuckjr
Re: Ferrari F2012
It seems Ferrari have no intent to go the Macca or Sauber way.
Watching F1 since 1986.
