That is an early image of the exhaust, when some bodywork was cut away, as it was burning. Compare that to the Alonso Ferrari, and you will see the change, to inward blowing exhausts. Also, have a look at the heat shield on the inside of the endplates, with Alonso driving. It protects more of the endplate, and it is obvious that exhaust is now being blown to the beam wing and deflected upwards. Very major change in ideas.Crucial_Xtreme wrote:They tried multiple exhaust "blowing" configurations during the Jerez test. Here they are clearly blowing towards the rear brake ducts. They've obviously not figured out which is the best.
Here is Alonso driving with the exhaust in the exact same position. As I said earlier they tried many different configs. Right click>view imagegilgen wrote:That is an early image of the exhaust, when some bodywork was cut away, as it was burning. Compare that to the Alonso Ferrari, and you will see the change, to inward blowing exhausts. Also, have a look at the heat shield on the inside of the endplates, with Alonso driving. It protects more of the endplate, and it is obvious that exhaust is now being blown to the beam wing and deflected upwards. Very major change in ideas.Crucial_Xtreme wrote:They tried multiple exhaust "blowing" configurations during the Jerez test. Here they are clearly blowing towards the rear brake ducts. They've obviously not figured out which is the best.
In every picture I've seen from Day 4, the car's ride height appears uniformly low.shelly wrote:I agree with others in remarking how low the rear ride height is in the picture: coul it be just a transient effect under acceleration?
