Ferrari 150° Italia
raceman
Re: Ferrari F150
Diffuser is not covered, but is's a simple one!
ESPImperium
ESPImperium
64
Re: Ferrari F150
Renault R31 style mirror mounts.
Also new air box and clever rear crash structure. The engine cover is McLaren MP4/24 inspired. Wheels need to be changed.
reikorp
reikorp
Re: Ferrari F150
I must have misscklicked & been redirected to the last year reveal. #-o
raceman
Re: Ferrari F150
H. Zedozil wrote:Are they used the same rim as last year?
same rim. visually not much difference than last year's car except some areas.
imightbewrong
imightbewrong
Re: Ferrari F150
Technical specification:
Carbon-fibre and honeycomb composite structure
Gearbox: Ferrari longitudinal gearbox
Differential: Limited-slip differential
Command: Semiautomatic sequential electronically controlled gearbox – quick shift
Number of gears: 7 +Reverse
Brakes: Brembo ventilated carbon-fibre disc brakes
Suspension: Independent suspension, push-rod activated torsion springs front and rear
Weight with water, lubricant and driver: 640 kg
BBS Wheels (front and rear): 13”
Raptor22
Raptor22
26
Re: Ferrari F150
this thread has become useless without pictures
raceman
Re: Ferrari F150
The wing:
imightbewrong
imightbewrong
Re: Ferrari F150
[quote name='MasterM' date='Jan 28 2011, 10:16' post='4804270']
[/quote]
ESPImperium
ESPImperium
64
Re: Ferrari F150
Nose appears to be quite a bit higher than the F10.
No pull rod suspension, they are still using push rod.
Re: Ferrari F150
Very mclarenesque (airbox-nose-sidepods front)
timbo
timbo
109
Re: Ferrari F150
Interesting beam wing.
Completely separated from the crash structure.
matt21
86
Re: Ferrari F150
raceman
Re: Ferrari F150
The diffuser:
H. Zedozil
Re: Ferrari F150
Ferrari point out the car will change a lot during the course of the tests.
Raptor22
Raptor22
26
Re: Ferrari F150
Looks very F2000 ish, the Ferrari Schmacher won his first WDC with.
