Big Tea
Sieper wrote:
17 Jun 2022, 13:37
Big Tea wrote:
17 Jun 2022, 13:26
Sieper wrote:
17 Jun 2022, 11:51
But with the rest they are not on the limit, so why take it early?
Because its 'life' will start from this week. They can be more flexible about changing it in future and in the 'extra time' gained there may be a development that would not have been included in an earlier engine change.
Nothing is for nothing, but getting back up to 10th place here is about as close as it gets.
They wont get an extra penalty for taking another ICE as they are on 2 used, and you can take 3. They wont be dropped from 10 to 20 if they take an extra ICE. it will just mean they are on the limit now already instead of later.
You are quite right, my apologies, I got it wrong.
Sieper
73
no worries, I think the question facing Ferrari is revert to turbo 1 or take unit 4. 10 places is quite a big drop for just one component. It is all a rather unlucky situation regarding that.
dialtone
108
Sieper wrote:no worries, I think the question facing Ferrari is revert to turbo 1 or take unit 4. 10 places is quite a big drop for just one component. It is all a rather unlucky situation regarding that.
It's an easy choice really: better to finish 4th than not.
Sieper
73
that would be my choice as well. Unit 1 can then be used on fridays and unit 4 on saturday and sunday alone. Plus, if it is a rainy weekend the race might be wide open anyway.
saviour stivala
Before FP-2 started FERRARI confirmed a grid place penalty for race start for Leclerc having taken control electronics number three
Xwang
29
If I have correctly understood, Ferrari has broken one or two ICE (Leclerc's last one with a broken valve, correct), at least two turbo and they now use the third CE.
Have all the components been used above their capabilities to squeeze too much performance or the CE was causing issues to the other components and they had to change the control logics in order to avoid breaking other ICEs and turbos?
dialtone
108
Xwang wrote:If I have correctly understood, Ferrari has broken one or two ICE (Leclerc's last one with a broken valve, correct), at least two turbo and they now use the third CE.
Only one ICE broke, PU2. It was likely broken by the overheating in Barcelona which broke the turbo and mguh. When the PU2 broke then in Baku, the valve stuff broke the new turbo.
It has nothing to do with keeping up with RedBull. When the engine broke in Barcelona Leclerc was on his way to dominating the GP by 20+ seconds, every engine was overheating that weekend, probably they made a mistake with temp sensors or somesuch.
The CE is just an extra CE, just in case, why not take an extra one of that as well?
FDD
FDD
62
dialtone wrote:
18 Jun 2022, 20:19
Absolutely right, when they put the 4th ICE this weekend, it is very clever to put and new CE in the pool with same penalty.
DR30
dialtone wrote:
18 Jun 2022, 20:19
Pretty sure the control electronics failed also during practice. Leclerc was unable to perform burnouts before performing a practice start and the message on the radio was "it's because of the turbo" then they changed the control electronics. Assume the "H" didn't function.
saviour stivala
The situation as is this season. It cannot but have all to do with keeping up with RBR/Honda, and same goes for RBR/Honda as the top spot is only between them two.
Those extra set of four power unit components, ICE – TC – ‘H’ and ‘K’, will cost Leclerc an extra nine grid drop slots compered to the eleven grid drop slots for that just one extra CE component. As for FERRARI/Leclerc the difference between grid slot eleven and twenty will make very little differences. there is nothing clever in this FERRARI move, as I am one hundred percent sure that anybody from on the grid that would have found himself in the same situation would have done the exact same move, namely extract the maximum that the rules allows with the minimum of penalty.
NL_Fer
82
They took the smart option by taking the 3rd powerunit on Friday with Turbo no1, than take a complete new powerunit no4 on Saturday. Now they can have both powerunits in the pool. Still have to option to take another turbocharger later on or take another new powerunit by that time.
ryaan2904
36
dialtone wrote:
18 Jun 2022, 20:19
How are we so sure that the valve stuff broke the engine? It could also be a turbo shaft failure or anything else
CFD Eyes of Sauron
F1NAC
163
ryaan2904 wrote:
21 Jun 2022, 07:28
dialtone wrote:
18 Jun 2022, 20:19
Turbo shaft failure has a distinctive sound when listening onboard. In Baku it was clear that engine went kaputt, when suddenly engine changed it's tone like something broke inside.
mzso
58
Why didn't they also change the battery? Would Leclerc had to have started from the pitlane then? (If not, then it doesn't seem to make any sense, not to change it as well.)
https://www.auto-motor-und-sport.de/for ... nik-mgu-k/
Haas having more MGU-K problems at Canada. Lots of MGU-K penalties for them this year I think. Ferrari may run into this problem if they also run their car lower - AMuS suggests that the Haas runs lower than other Ferrari teams and as such has been damaging the MGU-K somehow:
At most a suspicion. The Haas VF-22 rides lower than the Ferrari F1-75 and the Sauber C42, so it takes a heavier hit as the cars bottom out on bumps and curbs.
