Ferrari F2012
Hail22
144
Re: Ferrari F2012
Ah right thank you for the clarification, interesting the aero sensor is inside those slots as well...and its stepped if you look at the top of the slots you can see "something" there however 2/3rds of it is very dark/hollow.
Could this concept be linked to the floor? (Rory Byrne floor blowing air through)
Or nigh ridiculous concept?
Gilles Villeneuve
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Hail22 wrote:Ah right thank you for the clarification, interesting the aero sensor is inside those slots as well...and its stepped if you look at the top of the slots you can see "something" there however 2/3rds of it is very dark/hollow.
Oh no worries, I had to look back through pictures to make sure it wasn't new.
No quite sure, but possibly in a way. They look like vents(if we're speaking of the same thing) which I'm sure hot air from the engine comes out & mixes will lateral flow from the sidepods. Maybe, not sure.
Leon
Leon
Re: Ferrari F2012
is it intended to create similar effect?
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
Cuky
65
Re: Ferrari F2012
Leon wrote:is it intended to create similar effect?
No it is not. This thing Ferrari did this year is to accommodate their exhaust. 2nd reason is to use airflow over engine cover to take those exhaust gasses down to the diffuser, when they now can't do that with bodywork
Isak
Isak
Re: Ferrari F2012
[img]http://s15.postimage.org/u5jvtdqtn/111.jpg[img]
Not in the slightest no.
Reason: Removed image quoted from post above
shelly
shelly
136
Re: Ferrari F2012
I would not rule it out Isak.
Exhausts could be used as a rear flick. Coanda effect would give you a low pressure spot on the lower surface of the sidepod extension.
But probably is not that efficient comapared to blowing the edges of the floor.
twitter: @armchair_aero
Mazdaboy
Re: Ferrari F2012
New rear wing endplate fins (it's not a reflection :lol: ):
Every race ends when the chequered flag is out!
Owen.C93
Owen.C93
191
Re: Ferrari F2012
One is directing flow up and the other down, I'm not too sure why they are similar.
Forza Ferrari
Forza Ferrari
Re: Ferrari F2012
Guys, I have a few questions here, I need your help ^^
What is the stick aimed at? Is it a part of the suspension?? In green on the pic
What are the holes for?? Cooling purposes, or aero effect intended ? In blue
Finally, What tis thing in purple? Is it aimed at chaneling some air to the beam wing or what??
And also, it seems that the blisters on the engine cover disapeared ^^
Thanks for your help :D
Owen.C93
Owen.C93
191
Re: Ferrari F2012
Pullrod, cooling, wishbone, in that order.
Chuckjr
Re: Ferrari F2012
I've been trying to keep up with all the news, sorry I'd this is a dumb question.
Is there any way to know 100% sure that Ferrari is running or will be running the final version of the Byrne floor?
Watching F1 since 1986.
lombers
lombers
Re: Ferrari F2012
FORZA FERRARI wrote: And also, it seems that the blisters on the engine cover disapeared ^^
Yeah I noticed this too, is it my eyes playing tricks or are the blisters on the engine cover now gone with this revised exhaust layout? Will have to try and find some pictures from day 3 of the engine cover...
flickster
flickster
Re: Ferrari F2012
Sorry for all the double/triple posts earlier in this thread guys. I tried to post last night and nothing was showing even after a refresh or 10mins of waiting and then I check this morning and they all pop up.
Sorry about that.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
This morning. Exhaust in launch position. Flo-Vis at the rear
bhall
bhall
244
Re: Ferrari F2012
Man, they can't even get abandoning the exhaust right.
