Ferrari F2012
xpensive
xpensive
214
Re: Ferrari F2012
marcush. wrote: ...
alinkage may be a linkage but from that sketch you can easily derive that a fairly big (exagerrated)vertical movement of the hub is resulting in almost nil movement at the pullrod end and you need to acknowledge that this is not a good thing -AS you need to have a very short lever on the rocker and translate this into damper movement /torsionbar twist .Any slag ,give ,and flex will be a huge factor in this arrangement and you will surely have a hard time sorting this out.
That said I think most Formula 1 suspension is suffering in that area... :roll:
Give it up marcush, just wait til Ferrari presents the push-rod modified F2012-B, then this very thread will be all about
how stupid that pull-rod was to begin with and how politically smart it was of Ferrari to deny the obvious.
Just like with USF1, as I recall you were the only one to admit having a bleeding nose?
amouzouris
105
Re: Ferrari F2012
xpensive wrote:
marcush. wrote: ...
xpensive dont be so sure....scarbs opinion is VERY rarely off...and there are many more qualified people saying that there is no problem with the front pull-rods than just one or two people from the press saying that the front pull-rods is what is destroying the F2012...
that said...what are the political reasons for denying it 1000 times??
timbo
timbo
113
Re: Ferrari F2012
xpensive wrote:Give it up marcush, just wait til Ferrari presents the push-rod modified F2012-B, then this very thread will be all about
x, care to comment on the picture I posted?
hardingfv32
hardingfv32
35
Re: Ferrari F2012
Chuckjr wrote: why did their original solution fail so badly that they abandoned it completely after 6 months of study and just a single day on the track even though they knew it was the superior solution?
How do you know the exhaust layout is the problem? There does not seem to be much consensus about the exhaust treatment as you look over the field.
How do you know it is not something more fundamental than just the exhausts? Ferrari's performance has only fallen one position compared to last years performance.
Brian
bhall
bhall
244
Re: Ferrari F2012
Why are questions repeated as if repetition is going to change the answer?
marcush.
marcush.
159
Re: Ferrari F2012
x,I´m well aware of this .
And to be honest i think the pull rod is not their main problem...but then alonso already bagged his win of the year already so what...
The points haul upto now would justify forking out the money to design a new tub which is essentially what they´d need .
xpensive
xpensive
214
Re: Ferrari F2012
marcush. wrote:x,I´m well aware of this .
The F2012-B will be a red MP4-27, perhaps with an even lower nose to keep the pull-rod, but with a decent geometry? :shock:
elFranZ
Re: Ferrari F2012
Come on guys, there's no need to flame about a suspension layout, I think.
We're all making supposions, and here's mine:
As many skilled people repeated all together in the last few days, the two main areas were Ferrari lacks performance are top speed and corner exit. I hope everyone is ok about this.
I will resume what Mazzola said in the first part of his clever article, that's exactly what I believe: car "seems" to have serious aero problems. Looks like F2012 is paying a high drag coefficient for a small lift coefficient ( or downforce, if you prefer), that's all. From this point of view, McLaren has the best compromise, being not the fastest car on straights but very consistent on corners. In other words, it's efficient, being Efficiency = Lift coefficient / Drag coefficient. On the other side you have RedBull paying in terms of top speed while being still well balanced on corners (we're talking about saturdays, low fuel and free DRS).
I suggest to look at the tables with times and top speeds he posted, they're self-explaining.
And this doesn't mean that fixing exhausts will make it a rocket. Exhausts are just part of the matter, you have Acer ducts, cooling system, sidepods. All this stuff was designed for a specific configuration which never saw a race, if you miss an element the entire system won't work as desired.
So finger crossed, hoping next aero spec will prove right.
Chuckjr
Re: Ferrari F2012
Brian
I don't know anything nor am claiming to know anything for certain. That's why I'm asking questions---so I can better understand and appreciate the sport. I'm sorry if this just wastes people's time. That was the opposite of my intent.
Watching F1 since 1986.
bhall
bhall
244
Re: Ferrari F2012
There's no need in the world for an apology there, Chuckjr. None whatsoever. Ask away until you get the answer you seek.
FakeAlonso
Re: Ferrari F2012
Than the F2012 will look great. I would like to see something similar, not necessary copy Mclaren. Unfortunately I don't think they will do that.
Chuckjr
Re: Ferrari F2012
Thank you for your patience. I am trying to understand. I'll just rephrase a question with further input.
Ferrari show up in Jerez with their 6 month result for what they believe is the best possible start to the season for their 2012 car.
In just one day they abandon their exhaust solution (one of the most important aspects of the car from what last year and this year is revealing), and go to the trouble of cutting up the rear of the side pod, re-arrange the exhaust outlets (Im sure requiring re welding all kinds of new headers) and go with that and other mickey mouse re-arrangements for the rest of testing and the start of the race season. The fit and finish of the car now clearly shows evidence of rushing and pressure.
Yet, when they are asked about all this exhaust stuff, they claim their day 1 Jerez solution is actually the better exhaust and that they will develop it back at Maranello--or wherever--not on a track that that told them the truth of the matter.
How do they know it's the better solution if 6 months of study did not reveal what one day of testing did? Why will going back to Maranello help them more than actual track time with the exhaust they claim is better when 2 wind tunnels did not reveal this to them? That just does not make sense. It actually says to me that there actually IS a correlation problem with what the computers are telling them and what the track is telling them.
I'll not get into the second question and just stick with this first consideration.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
As Bhall said do not apologize for anything.
Chuckjr wrote: My first question is, if there is indeed no correlation issue, and they had from July 2011 till February 2012 to design the car, why did their original solution fail so badly that they abandoned it completely after 6 months of study and just a single day on the track even though they knew it was the superior solution? Does this, in the opinion of those here who really know what they are talking about, emulate that there is indeed no correlation problem, or does it say otherwise? That's not a set up question for saying it does point to a discrepancy, it's a real and open question. I want to understand based on your experience and facts.
You cannot properly simulate exhaust in the wind tunnel because the models are 60% and do not have working engines in them. So you're left with CFD. This is an area that Ferrari is admittedly behind other teams such as McLaren & Red Bull. But it's not an excuse, nor more than likely is the exhaust the only problem. Everything works together to create a package and if one piece is off or missing the entire car doesn't work as intended obviously. Scarbs mentioned something with the FWEP(Front Wing End Plates) and air.
I understand many thinking the original solution failed horribly and there's something there in a sense but Fry said it gave the most performance but it just wasn't race ready yet. Bad yes, but it seems if they can get it right, it will provide good performance.
There is talk that the advanced materials the team was using didn't perform as expected and more time is needed, so I think this plays a part in the troubles as well.
Really it's almost impossible to accurately answer your question because unless you're in the team, you never really know what the problem is. We're only speculating. As Fry said, they tried something aggressive and got it wrong. It happens. Happens more than it should at Ferrari but other teams are not immune either. So without knowing full details I'd say the tunnel correlation problems are probably fine but there's still work to do in CFD.
Chuckjr wrote:Second, and this is an even more speculative question, (that seems to be a synonym for this site and that's not intended to be derogatory since we are all just trying to combine minds to understand) if Ferrari is indeed able to make their original idea work, which failed so bad day 1 they abandoned it completely, why would it be a better solution than the proven McLaren or Sauber exhaust since we know those solutions work--esp the Macca solution? Ferrari could easily copy either of those and in doing so is nearly guaranteed a vast improvement, so is there truth to the theory that it is indeed a better solution from this decision to stay with day 1 Jerez exhaust? We all saw last year Macca just copied and pasted the RB blown diffuser solution, so pride of original design seems to give way to having a competitive car...maybe Ferrari has more pride, but that can't be answered conclusively here.
Well I don't really think it failed day one, but they knew at the end of the first test it need more work. I guess how it performed is up to interpretation.
I would think the team probably tried/simulated different exhaust solutions before deciding on the final spec. So they may or may not know if their solution is better or best, but it seems they think it will provide the best performance. As far as just copying the McLaren/Sauber/Red Bull exhaust solution it's not as easy as just making the right sidepods changing the exhaust pipes and doing it. It gets back to a package deal and how every bit of the car is made to work in unison. You couldn't put the McLaren sidepods on the F2012 and expect everything to work right.
Being that it's quite possible we won't see the updated exhaust until Spain, it's quite possible they've decided to go with a solution similar to another team, which requires modifying or changing about everything; Front Wing, modifications to the nose, suspension arms, sidepods, floor, turning vanes, radiators, engine packaging, engine cover, possibly the rear end, Rear Wing & diffuser, etc. Or it's possible they decided to keep the original, modify only the necessary pieces which would probably be less in quantity than using another teams solution and go with it.
I feel like I rambled on the post above. If it makes no sense, sorry. I'm very tired. And honestly it's a lot of speculation on certain things. Either way I hope it helped to answer your questions or perhaps give you a little better understanding.
edit: they used the original exhaust solution for more than one day. :)
bhall
bhall
244
Re: Ferrari F2012
OR...
The team is completely full of sh*t when they report that "correlation between the wind tunnel, CFD and the track are fine."
(If you believe they don't have issues in that realm, it pretty much forces you to believe that they don't know what they're doing.)
Chuckjr
Re: Ferrari F2012
Ok excellent. That really helps.
With all the millions of dollars they have for r&d, why on earth can they not make some sort of pulsing fan or something to simulate an exhaust in the wind tunnel model? Why is it not possible to make some sort of wind generating motor under the models casing (which would be hollow I assume) blowing through a 60% exhaust toob at the side pod exits? Surely something could be built to accurately simulate this? Could they not also attach a heater to it (like a million dollar blow dryer or something) so heat mapping/effect could also be modeled? Or are these reduculous considerations?
Just seems that would save them countless hours guessing on the track.
