Ferrari F2012
bonjon1979
bonjon1979
30
Re: Ferrari F2012
bhallg2k wrote:
bonjon1979 wrote:I agree that it's broad speculation however I would question your ascertion about low speed traction. i thought that they weren't that bad in this regard and it was stability in high lateral load that was causing the problems, making the car hard to drive and wearing tyres.
Well, no wonder the team's been struggling; they're not even on the same page!
Seriously, though, I think the author of the F1 Times piece somehow just deduced medium-speed traction issues based on Fry's answers. The team's been pretty explicit about their low-speed woes since Day 1. I think the results bear that out, too, because the F2012 has been strongest in situations where a softer than usual setup is optimal, e.g., rain in Malaysia and Monaco's normal nasty self.
That said, the F2012 does have tire wear issues, but I think they're just symptomatic of the main problems.
Yep, this weekend will answer a lot of questions about the car (or not as the case may be in this modern random world of F1)
bar555
bar555
Re: Ferrari F2012
I have summarized the F2012 pre season exhaust evolution here :arrow: link
There were at least nine different specs and i can not recall nothing similar from past . A really unique and extreme approach by a Formula 1 team , at least so far .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
ferrulin
ferrulin
Re: Ferrari F2012
And here is a first pic of the exhaust configuration Ferrari will try tomorrow!
http://www.marca.com/2012/06/07/motor/f ... 66876.html
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
ferrulin wrote:And here is a first pic of the exhaust configuration Ferrari will try tomorrow!
I see what they say, but I think that's the Spain/Monaco spec.
type056
type056
Re: Ferrari F2012
Today in Montreal
Scalex
Scalex
Re: Ferrari F2012
Every time I see something from MArca (and simmilar ones) and their so-called journalism, I have to btie my tonge.
But this time I can't... :
"La falta de apoyo en la zona trasera obligó a buscarlo en la forma tradicional: poniendo un alerón mayor "
Literally, "lack of downforce forced to look for it the traditional way: with a bigger wing".
Now I hope Red Bull and Mclaren don't get to know about it... uou! A bigger wing...! And those race stewards, always sleeping... they notice nothing.
Ok, of course they meant more rear wing, not bigger, but hwhat they wrote is completely different.
True as well; this is a small example, normally they are much worst.
Now having said that, from the pic it would look (to me) as if the air exit on top/before the exhaust exit was bigger , in fact so much bigger that it could well be that there's justa a piece of bodywork missing. If that's not the case, it would make sense to me that this was intended to channel/attach the exhaust gasses downwards. It would depend on the pressure/speed differential with the air coming from the top; if that makes sense when explained like this...
FakeAlonso
Re: Ferrari F2012
Two different front wings?
Gridlock
42
Re: Ferrari F2012
The only difference I can see is around the right FWEP, and that's just perspective isn't it?
#58
Cuky
65
Re: Ferrari F2012
maybe it is just an angle, but it looks to me like those two have different size of flap...
F1.Ru
21
Re: Ferrari F2012
look at the nuber bearing in the FW one says 5 nd another is numbered with 6/. so does it means that they bring slightly different FW for their two driver, with their own preference....
may be one suited more to alonso and massa prefer other one, so two different version of FW.
Or well it could be same but due to different angle it looks different. :D
Formula One is a game.............. but not any ordinary game for me
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
FakeAlonso wrote:Two different front wings?
I think so yes. The top element is smaller on the top wing versus the bottom. I don't think that difference is perspective.
amouzouris
105
Re: Ferrari F2012
if you look at the nose of the bottom fw u can see a lot more of the top part of the nose....so i think its purely perspective...also there might be slightly different fw angle...
edit: actually there might be slightly different shape on the outer part of the top flap...
Owen.C93
Owen.C93
191
Re: Ferrari F2012
Looks to me like the top one is clearly using a much smaller main flap, or significantly reduced angle compared to the bottom.
alogoc
alogoc
-10
Re: Ferrari F2012
here the difference
https://p.twimg.com/AuzEatqCIAIGCLj.jpg
via alex@AMorteF
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
beelsebob
beelsebob
85
Re: Ferrari F2012
alogoc wrote:here the difference
via alex@AMorteF
Nothing different there other than the camera angle.
