Ferrari F2012
Nando
Nando
Re: Ferrari F2012
Ok now im with you, i also noticed now when you said it that they really are not the same thing or have the same purpose.
RB one is basically just a flap on the outside of the diffuser whereas the Ferrari one actually sends gases into the diffuser.
mx_tifoso
mx_tifoso
Re: Ferrari F2012
Kiril Varbanov
147
Re: Ferrari F2012
Parts unpacked at Germany:
Owen.C93
Owen.C93
191
Re: Ferrari F2012
f1316
88
Re: Ferrari F2012
Owen.C93 wrote:Image
The resonant chamber on the exhaust is back. Am I correct in saying this is in an effort to stabilise the flow coming through the exhaust, making it, and therefore the balance more, consistent?
Is there anyway in which this would boost top speed?
I notice that slot on the side of the exhaust housing is there, but it keeps disappearing come race day.
Re: Ferrari F2012
Matt Somers
Matt Somers
179
Re: Ferrari F2012
Covered resonator chambers recently albeit the Red Bull one: http://www.somersf1.blogspot.co.uk/2012 ... nsion.html
f1316
88
Re: Ferrari F2012
Very interesting, thank you. Could you possibly expland on this conclusion: "Ferrari have already been using a Resonator / Expansion Chamber this season but I feel theirs is primarily focused at tuning the exhaust length rather than utilising the benefits that can be gained under off throttle events."
Owen.C93
Owen.C93
191
Re: Ferrari F2012
Because only Newey can be the aero genius of-course!
.poz
.poz
53
Re: Ferrari F2012
f1316 wrote:"Ferrari have already been using a Resonator / Expansion Chamber this season but I feel theirs is primarily focused at tuning the exhaust length rather than utilising the benefits that can be gained under off throttle events."
Look at the size of the resonator chamber on both Ferrari and RB: there is no way something of that size can store a volume of compressed gas big enough to blow off throttle.
IMHO on both car the main purpose of the chamber is to smooth pulses of single cylinder and changes in exhaust flow on gear shift. I think aerodynamic devices doesn't like abrupt changes in a flow.
Matt Somers
Matt Somers
179
Re: Ferrari F2012
LOL Owen, of course not, the use of the chamber will of course help with off throttle just like Red Bull's does however if we consider that Ferrari have changed exhaust position from their original course (more than likely a more ideal tuning length) the chamber should help to bridge the gap of the exhaust runners not being their optimum size. The other thing that the chamber should do is help in a specific rev range, tuning the size of the chamber would result in a differing effect on the engines performance.
Matt Somers
Matt Somers
179
Re: Ferrari F2012
I totally agree, they aren't using it to blow off throttle, however as a result of it's primary function it may also help assist in the transition from part to off throttle (aero wise)
Spankyham
Re: Ferrari F2012
Has the bottom of the exhaust channel been raised a little? I can't find a closeup image of the same section to compare. Looks like it might have changed.
"He was the fastest driver I ever saw - faster even than Fangio"
_______________________________- Mike Hawthorn on Alberto Ascari
Isak
Isak
Re: Ferrari F2012
This is from Canada, seems it was always raised a little.
hardingfv32
hardingfv32
35
Re: Ferrari F2012
.poz wrote:IMHO on both car the main purpose of the chamber is to smooth pulses of single cylinder and changes in exhaust flow on gear shift. I think aerodynamic devices doesn't like abrupt changes in a flow.
That is a myth.....
The chamber simply changes the rpm location of the exhaust's peak pressure point for best exhaust extraction.
Brian
