Ferrari F2012
C Plinius Secundus
C Plinius Secundus
Re: Ferrari F2012
adam2003 wrote:They're usually called "rear brake duct fins", and AFAIK, as far as the area of the fins is within the maximum value, the angle is free.
adam2003 wrote:Ok. I mean in general like the front wing angles they create that feed air to the next areo device on the car has it got to be exact the angles it flows off , their is no tolerance of 0.1mm for example?
Almost every manufactured part has a measurement tolerance, but in the case of a top racing team, those values are usually known only to a few people within the technical area of the team, designer, manufacturing engineer, etc.
Also, remember these parts flex under load (even minimally), so its shape and angle may vary (even a tiny fraction)
The rear brake duct fins are meant to generate downforce, and they also interact with the beam wing and the rear wing.
alessio
Re: Ferrari F2012
Massa and Alonso have two different front wings
amouzouris
105
Re: Ferrari F2012
nice to see massa has the new diffuser and rear wing as well!!
suburbano
suburbano
Re: Ferrari F2012
amouzouris wrote:nice to see massa has the new diffuser and rear wing as well!!
They usually do that when there are a lot of parts to test. They split the load and each one tests different parts, then all the info is combined. But I don't like this because Alonso is much more consistent with his lap times so he should be the one testing at least the important parts to get more reliable results.
alessio
Re: Ferrari F2012
amouzouris
105
Re: Ferrari F2012
I mean the diffuser and rw Alonso has had for 2 GPs now..the one massa tested and gave it to alonso
alessio
Re: Ferrari F2012
McMrocks
McMrocks
32
Re: Ferrari F2012
I'm quite confused. in the 1st sector Alonso is faster than Vettel who had maybe a not so much fuel. I would have declared the 1st sector as Red Bull-sector yesterday. Sector 1 contains a low speed corner and a few high speed corners. According to somebody who told Ferrari has a lack of traction in low speed corners and a lack of DF in high speed corners the RB has to be better than the Ferrari in sector 1.
suburbano
suburbano
Re: Ferrari F2012
Ah, ok, I misunderstood
f300v10
f300v10
185
Re: Ferrari F2012
Notice one car running a new diffuser, different than the India/AbuDabi model. The top one is the newest, with a squared off end to the Gurney flaps, while on the India model the Gurneys flow around the edge.
New:
Older:
Forza
238
Re: Ferrari F2012
US GP - FP1
Side comparison of old&new endplate design
froggy
froggy
Re: Ferrari F2012
looks oddly familiar to the famous Hungary end plates
wrcsti
wrcsti
Re: Ferrari F2012
anyone care to explain about the central DDDish part of the diffuser?
aral
aral
26
Re: Ferrari F2012
froggy wrote:looks oddly familiar to the famous Hungary end plates
Yes. They are the same.
Re: Ferrari F2012
Felipe has the new FW on FP2.
I think both cars are on the same aero config now.
Felipe's car has a lot better traction out of the final corner, Alonso is always sideways there.
