Red Bull RB9 Renault
CHT
CHT
Re: Red Bull RB9 Renault
new Infinity livery on the sidepod should make life easier for commentators
Holm86
245
Where can you follow the launch?? I cant find it on their webpage.
diego1960
I don't know, sidepods appear slightly larger than the ones on RB8, although I might be mistaken.
"Being second is to be the first of the ones who lose." - Ayrton Senna
stfn_ger
stfn_ger
diego1960 wrote:I don't know, sidepods appear slightly larger than the ones on RB8, although I might be mistaken.
I think you are, just compare:
also, if I'm not mistaken either, the barge boards should be at the same position, which would be the max. allowed bodywork width.
Holm86
245
Looks excatly the same as last year. But that was expected. Only difference is at bit smaller sidepod intakes and new step on the nose.
Diosfenix
Diosfenix
i70q7m7ghw
i70q7m7ghw
49
Not sure about the purple...
Anyway, interesting take on the modesty panel. Much like Sauber, they've chosen to stick with the step, and just improve the airflow around the transition. Sauber have chosen to "fence" the side of their nose, so the airflow doesn't spill over. Red Bull have chosen to do the opposite. My guess would be neither team wanted the additional weight of a full modesty panel, which would be very high and very far forward. That or this is actually more efficient than a flat nose... I would find that hard to believe.
CHT
CHT
diego1960
stfn_ger,
the angle doesn't help though so I'm still not sure. I can't see anything special on this car compared to the previous one. Although we must always have in mind that Newey might have some aces up his sleeve that he won't reveal until the last test.
Sidepod comparison. Couldnt find a better angle
Worst launch ever.
CHT
CHT
notice there are couple of vertical blade above the side pod just above the air duct.
http://img833.imageshack.us/img833/2006/rb91.jpg
Interesting that they've added a monkey seat. Last year we were told by certain people that a monkey seat means the team are struggling with downforce. I wonder if those same people will claim the same now...
I like the look of the car. The purple colour scheme looks good in the pictures. Hopefully it will help the commentators pick out the RB from the STR this year (some struggled last year at times).
The sidepods have been reworked and there is a lot of floor plate in front of the sidepods. Presumably this helps scavenge the front wing as well as helping to flow air to the rear.
Interesting that RBR have decided to run a hybrid-step nose rather than a full aeropanel like McLaren and Ferrari. Perhaps the rear benefits from the flow coming off this area?
It's going to be interesting to see how this car is developed compared to the McLaren and Ferrari as it uses the ramp exhaust compared to the pod exhaust. I get the feeling that the RedBull might be running out of development potential with this series of car (RB6-9) compared to others - albeit because they started ahead and the others have been catching up a lot of the time. Will be interesting to watch.
Juzh
161
Craig Scarborough ‏@ScarbsF1
@redbullf1spy 'Launch' over, car covered up, sunday afternoon wasted to see a nose cone from a distance in a dark warehouse
Either they're really hiding something, which is unlikely, or they're afraid competition might realize they simply dont have an answer for 2013.
