Ferrari F138
amouzouris
105
Re: Ferrari F138
Matt89 wrote:
amouzouris wrote:On the first photo stefan posted you can see how they've cut out part of the engine cover to aid cooling revealing the radiator on top of the gearbox, so the second inlet behind the engine intake is used for cooling, not for the possible DRD
Last year the intake behind the airbox looked smaller and this year that zone is not part of the whole engine cover, as it used to be on the f2012. It could be easily enlarged to be both a gearbox cooler and a DRD intake (as it was on Mercedes last year).
You are right! i meant at the moment it is used for cooling and it is not just hollow as people suggested!
Matt89
Matt89
Re: Ferrari F138
Let's wait and see how it develops for Ferrari, hoping for track confirmation of windtunnel data this time.
"Mi chiedete quale è la differenza tra la F1 eroica e quella attuale. Beh, è come se prima si camminasse in equilibrio su un filo sospeso a strapiombo sul Grand Canyon. Ora quel filo è ben teso in camera da letto, a un palmo dal materasso: l'abilità richiesta per camminarci sopra è la stessa, ma la sfida è cambiata per sempre".
- Stirling Moss -
"Se gommo tiene, io vince gara! Se gommo non tiene, io come bomba dentro montagna."
- Markku Alen -
Nando
Nando
Re: Ferrari F138
Ferraripilot wrote:The mass of the sidepod and exhaust exit is higher than anyone on the field. Comparison profile pics easily show this. Yes, they are small sidepods, but they are higher and I would say not necessarily smaller than many others. F138 simply has more flow around the floor area because the mass is placed higher. An aero gain is more beneficial than a CoG gain in this case, they should hope anyway.
Ferraripilot wrote:Don't let your eyes fool you with this car, yes it has a very tight back end but understand the exhaust exits a few CM higher than other teams which simply allows us to see under the exhaust area more easily which gives the illusion that it's tighter than it may be. I do not specifically see how the car is tighter than others so far,
I thought that was the discussion point?
Point being it was irrelevant if they had more mass higher up.
Nando
Nando
Re: Ferrari F138
Keep in mind this isn´t perfect angles but somewhat close,
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F138
Very good initiative, but i can't see any difference sadly
Nando
Nando
Re: Ferrari F138
Lorenzo_Bandini wrote:Very good initiative, but i can't see any difference sadly
You can´t see the Red Bull side pod and the Ferrari side pod? they are miles apart.
(sidepod-floor edge)
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F138
My eyes are not in very good shape.
Edit : i can see the sidepods difference, but not the floor
raymondu999
Re: Ferrari F138
The scale is off I think. Look at the tyres - you shouldn't be able to see two silhouettes like that.
失败者找理由,成功者找方法
Owen.C93
Owen.C93
191
Re: Ferrari F138
Can you link the 2 images you used?
Nando
Nando
Re: Ferrari F138
Made a slightly better one, again as i said it´s not perfect angles but it´s close enough to see there´s a massive difference in sidepod undercut.
Can easily be seen by comparing the offset in rim vs offset in sidepod waistline.
Both have this smoothing out at the bottom of the sidepods so i simply drew the line where the paint ends, before the smoothing bit.
Ferrari image,
http://www.f1technical.net/forum/viewto ... &start=255
Red Bull image,
http://www.f1technical.net/forum/viewto ... &start=150
Would love to get two near idenctical angles as that would be optimal.
Ferraripilot
21
Re: Ferrari F138
raymondu999 wrote:The scale is off I think. Look at the tyres - you shouldn't be able to see two silhouettes like that.
Yup. I cannot deduce anything from the above overlay.
Have a look at the side profile comparisons of the various cars, just notice between mclaren for instance that their sidepods have their mass lower and the exhaust exit is lower by comparison. I believe exiting lower maintains more exhaust velocity as the exhaust retains more of its speed when it has a shorter path to travel prior to the diffuser. F138 is clearly placing more weight on laminar flow around and under the exhaust exit than other teams otherwise Ferrari would have not made this area so large and exit the exhaust so high.
heho07
heho07
Re: Ferrari F138
@ amouzouris
I can not see space between gearbox and floor.
Cant you show me in pic where is it.
Thanks.
heho07
heho07
Re: Ferrari F138
@ Nando
Please make a gif pic.
GrizzleBoy
GrizzleBoy
35
Re: Ferrari F138
I think its quite easy to see what he's showing.
amouzouris
105
Re: Ferrari F138
heho07 wrote:@ amouzouris
Thanks.
I have a blogpost coming up explaining it!
