Red Bull RB9 Renault
f1rules
f1rules
639
Re: Red Bull RB9 Renault
joeyg02 wrote:Out of all those Jerez pictures, I kept scrolling for a look at the diffuser. When I saw it I laughed. I'm thinking Red Bull is still holding their cards.
i think both rb and mclaren are still developing their versions, if you look at both ferrari and merc they seem to use the same concept of expanding the diffuser height
http://www.formule1.nl/media/uploads/me ... 663.36.jpg
http://www.formule1.nl/media/uploads/me ... 1949.3.jpg
http://www.formule1.nl/media/uploads/me ... 2195.5.jpg
munudeges
munudeges
-14
Yer, I think that's going to change at some point in the not-too-distant future.
In terms of the exhaust systems I think Lotus and Red Bull have it right. I was surprised Sauber dropped what they had. You really need to coax the exhaust gas to where you want it to go along the bodywork because the exhaust are such a long way from your intended target. The bodywork behind Red Bull's exhausts is completely seamless in a way that Lotus's isn't and I find the shape where it slopes away in three dimensions quite curious. Ferrari and McLaren seem to just be putting it into an area and I'm not sure that's going to yield as much further development.
Forza
238
Jerez day 2
240
The chassis is even more extreme than the previous cars.
especially the splitter area, at the expense of driver comfort it seems.
If you decrease the cockpit floor area, you inadvertently increase the splitter area and also streamline the flanks of the car.
If you look carefully you will see the almost shrinkwrapped appearance of the splitter bow where the drivers rump should be.
It is safe to say rebull has even more downforce in the body of the car.
A lot of high pressure sits in that area.
Matt89
Matt89
Apart from the nose duct, looking how the beam wing is mounted (and maybe ducted) it is clear that Newey liked Sauber C31 quite a lot.
"Mi chiedete quale è la differenza tra la F1 eroica e quella attuale. Beh, è come se prima si camminasse in equilibrio su un filo sospeso a strapiombo sul Grand Canyon. Ora quel filo è ben teso in camera da letto, a un palmo dal materasso: l'abilità richiesta per camminarci sopra è la stessa, ma la sfida è cambiata per sempre".
- Stirling Moss -
"Se gommo tiene, io vince gara! Se gommo non tiene, io come bomba dentro montagna."
- Markku Alen -
FrukostScones
Wow, that's alot of rake there.
GrizzleBoy
GrizzleBoy
35
Sure that isn't under braking?
I see tyre smoke.
jaba.hut
Full speed. DRS fully open. That smoke is actally dust.
Chasis_1992
GrizzleBoy wrote:Sure that isn't under braking?
I see tyre smoke.
Look the DRS. It's may be water ;)
miguelalvesreis
miguelalvesreis
I see tyre smoke.
DRS is activated. So, not under breaking. Seems to me normal RB rake
Lurk
rake is normal for RBR but front camber is massive :shock:
And still flexi-FW.
JAllen
JAllen
I thought Pirelli set a max camber for the cars? That looks pretty extreme.
Huntresa
Huntresa
Nice flexi wing :D
