Ferrari F138
KennyBama
Re: Ferrari F138
I'm grateful for the very intelligent people on this forum. I'm all about learning about F! and thank you!
Re: Ferrari F138
radosav wrote:...
"We do expect a similar advantage from working the exhaust last year, nothing more."
This I don't believe... 3 different exhaust solutions for a similar advantage as last year, only if one doesn't lose any of engine's power and the other produces just 373 K temperature...
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.
joeyg02
Re: Ferrari F138
otbsti wrote:
gilgen wrote:In the second photo, ignore the hole. Look at the amount of narrowing caused by the pylons!
That was noteworthy, but I'm talking about the interior of the nose cone and the obvious electrical connection running to something inside. Wonder if Ferrari truly went after this idea: http://www.youtube.com/watch?v=mJybR-uW ... e=youtu.be
That has to be the most complicated engineering i've seen on the nose of a car. It seems to be too much trouble for a team to realistically be using it (never know though), but I LOVE this system. It's one of the most brilliant things i've seen.
Drafting & Design Engineer - I crave information & live in a never ending quest for answers to whatever piques my curiosity.
Joey Griffin - Owner - JG GraphX.
Lifelong Motorsport Fan from Southern Georgia, United States.
Chuckjr
Re: Ferrari F138
Crucial_Xtreme wrote:So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.
Yes I am blind. #-o Please show me the second opening, I cannot find it. :wtf:
edit: is it the circular hole under the wishbone :?:
Watching F1 since 1986.
joeyg02
Re: Ferrari F138
He's right. There are two holes. If you look at the picture where you can see the mechanic holding the nose with the wire hanging out of the nose there is a very small oval hole under the opening for the bigger intake.
Clew
Re: Ferrari F138
Just looking at Forza's picture...Does anyone know what the white chalk 301FE115 markings indicate? :?
“Championships are won in the first half of the season, not just the second half” Raikkonen
Chuckjr
Re: Ferrari F138
I found it now. Its a razor thin strip behind the shark mouth. At least I hope that's it. :|
raymondu999
Re: Ferrari F138
Clew wrote:Just looking at Forza's picture...Does anyone know what the white chalk 301FE115 markings indicate? :?
http://img2.auto-motor-und-sport.de/Fer ... 662751.jpg
Perhaps they're evaluating tyre/suspension setup changes. This way they can look at the tyre and then compare to their notes to see what setup 301FE115 was on.
失败者找理由,成功者找方法
Mr.G
34
Re: Ferrari F138
Crucial_Xtreme wrote:So there is two separate openings below the nose. [...]
Yes this is right, I did this picture about 20 pages back Image
StrikeForceF1
StrikeForceF1
Re: Ferrari F138
Whats your thoughts on what the shark mouth is for Crucial....seems to me way too big just for driver cooling....Imo I don't think its for Kers cooling as they have a cooling inlet just behind the airbox inlet same as last year....so I think they are up to something tricky.....good to see some innovation from them..... =D>
On a side note the pic you posted of the diffuser is there some sort of flat plate running horizontal and parallel to the tarmac or is it just my eyes......sort of reminds me of the old style diffusers that teams were allowed to run......
Redragon
Re: Ferrari F138
The edge of the rear wing is bended towards outside, so I guess it works as the other two flaps added this year on the rear wing.
Forza
238
Re: Ferrari F138
F1 test - Barcelona T02 - day 3
zoro_f1
-2
Re: Ferrari F138
you have a couple of HR picture's which point's this whole. On them it is more clear to see the segment... you have to go one page back... number 51.
Yes this is right, I did this picture about 20 pages back http://papermodelers.sk/hostimages/cgSX ... OyTi5C.jpg
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Mr.G
34
Re: Ferrari F138
Sure I have now, but when I was doing the picture, there was discussion if it is a hole or not. I just want to point out, that I noticed the two holes way earlier but nobody matter that time. Even now :lol:
