Ferrari F138
amouzouris
105
Re: Ferrari F138
Running without a Y75 winglet (monkey seat) ^^
Forza
238
Re: Ferrari F138
BCN T03 - Day 4
Hail22
144
Re: Ferrari F138
whoa whoa, cooling fins on the engine cover?
Gilles Villeneuve
Re: Ferrari F138
via Matt Somerfield
Matt Somerfield ‏@SomersF1
Ferrari F138 - New 7 Tier Front Wing on for @alo_oficial notice the change in Endplate & Footplate ethos
Re: Ferrari F138
amouzouris wrote:Running without a Y75 winglet (monkey seat) ^^
Which is to say, plenty of grip in the rear, right?
Autosport:
Alonso was the quickest of all so far today in the first sector, set a personal best in the second, but lost out in the third.
So, good top speed, good mid-speed/high-speed corner traction, mechanical grip somewhat lesser, could that be a noteworthy verdict at the moment?
Nando
Nando
Re: Ferrari F138
Or a small conscious slow down in the last sector to keep people in the dark of their ultimate performance.
So much floor!! :)
RicerDude
27
Re: Ferrari F138
Sky Sports were saying yesterday that the car looked like it lacked traction so that makes sense.
Re: Ferrari F138
Hail22 wrote:whoa whoa, cooling fins on the engine cover?
http://i.imgur.com/VMBrO35.jpg
Those are the rag's foldings. or are you talking about the low-left things that appear to stand out?
amouzouris
105
Re: Ferrari F138
@Vanja We can't really say that as the monkey seat doesn't produce almost any downforce. It is used to help keep the flow attached on the RW. So if they are not just testing the effects running without it, then we can say that they are not experiencing any problems with early detachment of the flow on the RW.
P.S. The monkey seat induces quite a lot of drag for the very little downforce it produces
infy
infy
Re: Ferrari F138
Well we had reports yesterday that Ferrari is still struggling with traction in slow corners. Maybe off throttle engine maps are not as good as on the Reno engines and so there is more of a balance shift when applying power, which upsets the car.
Hail22
144
Re: Ferrari F138
No stefan not the rags mate look directly south of the exhaust ramp and look against the engine cover...there are lumps/sharp edges protruding out slightly
Gilles Villeneuve
Re: Ferrari F138
amouzouris wrote:@Vanja We can't really say that as the monkey seat doesn't produce almost any downforce. It is used to help keep the flow attached on the RW. So if they are not just testing the effects running without it, then we can say that they are not experiencing any problems with early detachment of the flow on the RW.
So... plenty of grip at the rear. :D
Joking aside, I didn't really think that it produces much DF (and it's clear that the L/D ratio is low. What I concluded is that using the little monkey helps in some way when you have problems at the rear. Since it's not solving drag issues, it's helping with the grip in some way... Is that fair to say?
amouzouris
105
Re: Ferrari F138
Yes. That is basically it
Re: Ferrari F138
Barcelona (Test 3, Session 2) - Day 4 (03.03.2013)
High resolution: 1 | 2 | 3(back/diffuser) | 4 (top) | 5 (top) | 6 (exhaust) | 7
GrizzleBoy
GrizzleBoy
33
Re: Ferrari F138
This car is the back end of an FW34, mid of an MP4-27/8 and their own front end.
