Lycoming wrote:I think you greatly underestimate the difficulty of determining the integrity of a composite structure in such a condition from the information that they would have had at the time.
I saw that too but I don't believe what's being described in the article is new.F1.Ru wrote:
Ferrari's diffuser has gained a new channel under the rear crash structure.
http://cdn.images.autosport.com/editori ... 019991.jpg
Modified diffuser for Ferrari © XPB
Much like the Mercedes solution, this is a way to circumvent the rules that limit the diffuser to a 125mm height and the ban on openings in the diffuser.
In the middle of the diffuser, a dipped channel is visible. The scoop formed by this dip is legal as its opening is formed by an extension of the starter motor hole.
Above this scoop, the diffuser rises to about 200mm, far more than the 125mm maximum height. The scoop masks this height and forms the surface that meets the height regulations.
To make this duct produce downforce, airflow needs to pass over it. This is probably the flow that passes tight against the sidepods, coke bottle shape and up over the middle of the diffuser.
Although this duct creates a little more volume in the diffuser, it isn't another form of double diffuser. The potential of the extra duct is limited by the crash structure mounted above it. So this diffuser channel is not likely to become a must-have addition for all teams.
Thanks, I too think that the TV images were pretty conclusive about the damage.bhallg2k wrote:http://www.chinadaily.com.cn/sports/ima ... f44e02.jpgLycoming wrote:I think you greatly underestimate the difficulty of determining the integrity of a composite structure in such a condition from the information that they would have had at the time.
That is spot on and the only thing that I thought. With a safety crazed FIA, you'd think having a severely damaged front wing (when we all know what happens when they fail) would be more than enough for a black flag - come to think of it, I didn't see one shown to Alonso....... why?bhallg2k wrote:There were also sparks. Lots and lots of sparks. Also the very strong possibility of a black flag.
Like everyone else, they probably assumed he would stop anyway. He then retired mere seconds after many of us said, "What the..." when he didn't stop, which didn't give the FIA much time to do anything about it.Cam wrote:[...]come to think of it, I didn't see one shown to Alonso....... why?
The chances that it would hold were next to nothing. You don't need data or be an expert to notice the gamble would never pay off. Perhaps they were hoping the FW broke off without getting underneath the car, but that's not a difficult gamble NOT to make either, because you still would then need to stop due too much downforce lost.Cam wrote:It was a gamble, pure and simple. If they made it around one more lap, they might have stopped for slicks - skipped away and won the race - then they'd be geniuses who made the right call.
Brundle said the only thing scarier than a front wing failure is a stuck throttle - that me is a critical failure.
Assuming it would have hold, they would not have been heroes. The decrease in downforce would be substantial and would further decrease due parts of the endplate being scraped away. Alonso would had been in the pits at the end of his second lap, with alot of ground lost to his nearest competitors. He would have lost the avoided extra pitstop on track anyhow.wesley123 wrote:Well clearly the Ferrari team thought the wing would hold long enough to make the stop. It is all part of the game, and like Cam said, if the call did work out they would have been heroes.
But I guess it is easy to say how much Ferrari sucks after this decision when you already know what happened.
You have to evaluate the decision, not the outcome.wesley123 wrote: But I guess it is easy to say how much Ferrari sucks after this decision when you already know what happened.
I am doing that, but the rest seems fixed on "omg the wing was loose they were never going to mke it anyways, ferrari's tactics suck!" Which is, as I said, very easy to say when you already know what happenedAnthonyG wrote:You have to evaluate the decision, not the outcome.wesley123 wrote: But I guess it is easy to say how much Ferrari sucks after this decision when you already know what happened.
