Canda 2013 - Friday (07.06.2013)
Edit: Wild A**Guess removed since it didn't survive a secoond, closer look.Robbobnob wrote: Vortex generators to excite the airflow through the slots and keep the flow attached on the upper element?
Not sure what that picture is designed to represent, or where it comes from, but...wouldn't the flow TO the wing be pretty constant over the full width of the wing, rather than be concentrated on small part of the wing? For instance, the flow over the central part of the main plane, would be diverted sideways by the underbody deflectors, so influencing the entire process.shelly wrote:@henra: the flow angle in that zone of the front wing is much more oblique that one would think - see this picture as an example (and that is a very old wing, much less loaded):
http://www.gcdata.gr/c3/688_47a5581028f ... c51b03.jpg
So the vg have a moderate angle of attack compared to the flow, just enough to work correctly
Also the details at the rear (before the rear wheel and in the diffuser strakes) look a new generation compared to the previous ones
When you show a CFD solution, you can select which streamlines you want to show. If you show all of them, the picture can be very confusing.gilgen wrote: ...wouldn't the flow TO the wing be pretty constant over the full width of the wing, rather than be concentrated on small part of the wing? ...
Interesting!shelly wrote:@henra: the flow angle in that zone of the front wing is much more oblique that one would think - see this picture as an example (and that is a very old wing, much less loaded):
