Ferrari F138
emmepi27
emmepi27
141
Re: Ferrari F138
Asimmetric body in FP3? I'm pretty sure of that for FP3 (note flow vis) but not sure for qualifying...
this is the orginal photo http://formula1.com/wi/enlarge/sutton/2 ... 21se16.jpg
Massa: http://i.imgur.com/rMXedjU.jpg
right side:http://i.imgur.com/pMQKft8.jpg (note the vent, grill, and the nolder)
left side: http://i.imgur.com/L04tOW7.jpg (no nolder and closed vent)
Cooling problem on the right side?
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
No mention of new floor diffuser, but here's F1.com analysis of some F138 updates in Singapore.
aral
aral
26
Re: Ferrari F138
emmepi27 wrote:Asimmetric body in FP3? I'm pretty sure of that for FP3 (note flow vis)
It is just that they were trying different solutions on each car at different times. Photos were taken at differing times, so no question of asymmetry.
Hobbs04
Hobbs04
Re: Ferrari F138
Cuttered pylons? Anyone have photo? I'm struggling to figure out what cuttered is.
Edit never mind figured it out
tony77g wrote:another detail of the difference between Alonso e Massa during FP2
http://www.zaslike.com/
emmepi27
emmepi27
141
Re: Ferrari F138
No, the photos were taken at the same times, at the start of FP3, when Alonso has run with flow-vis on left side of floor:
right side with bulge: http://i.imgur.com/rXKMd2w.jpg
left side without bulge: http://formula1.com/wi/enlarge/sutton/2 ... 21se16.jpg
I can't confirm if this solution was here in the qualifying too, but i'm pretty sure that it was here in FP3 :wink:
So, if Ferrari has used it in qualy, we should see it in race tomorrow! :idea:
EDIT:
Now i can confirm! Both cars with asimmetrical body! Emmepi "Eagle eye" 27 :mrgreen:
tony77g
tony77g
36
Re: Ferrari F138
comparison spa singapore monza
Re: Ferrari F138
EDIT:
http://img94.imageshack.us/img94/3605/dxdu.jpg
Well blow me away and slap me silly!!! Now why would they do that ?????
Would they be trying to get more traction on one wheel than another to get better left/right balance in some specific corners ?
Maybe 1 side gives them higher downforce but less stability so they're trying to get a blend ?
Re: Ferrari F138
It hasn't gone unnoticed that Ferrari moved to the Sauber type exhaust a while back but that Sauber has recently moved away from that and move to the RBR over under exhaust.Where they use scoop like bodywork to grab some of the air going around the outside of the body to suck more heat out and energize the air under the engine cover and feed the diffuser.
tpe
tpe
-4
Re: Ferrari F138
diffuser wrote:It hasn't gone unnoticed that Ferrari moved to the Sauber type exhaust a while back but that Sauber has recently moved away from that and move to the RBR over under exhaust.Where they use scoop like bodywork to grab some of the air going around the outside of the body to suck more heat out and energize the air under the engine cover and feed the diffuser.
Is it possible that the ENGINE cannot handle an RB style exhaust?
Or is it just a matter of Ferrari proud?
LionKing
LionKing
Re: Ferrari F138
tpe wrote: Is it possible that the ENGINE cannot handle an RB style exhaust?
Sauber uses Ferrari engine.
sucof
25
Re: Ferrari F138
Ferrari's upgraded wind tunnel opening in October:
http://www.autosport.com/news/report.php/id/110112
sucof
25
Re: Ferrari F138
Druk Lager wrote:i hope new tunnel will finnaly show them what they shouldnt of abort mid 2012!
TILT THE BLOODY ENGINE
Haha, you're funny :)
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
Ferrari F138 Singapore Update Analysis from GA..
via AutoSport
max_speed
max_speed
Re: Ferrari F138
http://www.gptoday.com/full_story/view/ ... _Mercedes/
how true could it be ?. can some throw a bit more light on effect of tyre construction on car's aerodynamics?.
max_speed
max_speed
Re: Ferrari F138
diffuser wrote:I can't see that the new tunnel will be that much better than Toyota's. They have a new aerodynamicist as well.
ideally they could use this year's car as test bed for updates coming out of new wind tunnel. this must give them enough time to get ready for 2014 car's updates
