Red Bull RB9 Renault
Owen.C93
Owen.C93
191
Re: Red Bull RB9 Renault
Just looks like a little vortex generator.
Juzh
161
They've had it in singapore already if I am not mistaken.
emmepi27
emmepi27
141
Juzh wrote:They've had it in singapore already if I am not mistaken.
Correct!
But now we can see it very close for the first time!
gandharva
252
SectorOne wrote:Running asymmetric cooling holes on the car as well.
http://i.imgur.com/erQMkXU.jpg
Not the first time they did this.
Correct!
Singapore shots are way better imho.
240
Is 4 wheel steering allowed in F1?
Joie de vivre
no
SectorOne
ringo wrote:Is 4 wheel steering allowed in F1?
That´s funny. I thought about exactly the same thing when i watched rear view camera of the red bull.
I know it´s the tire flexing but the thought actually popped up in my head.
Hobbs04
Hobbs04
gandharva wrote:
gary123 wrote:
Why the T-tray of the car is hot? :-k
Because it was scraping the ground. Webbers car was set up to low for first stint in FP1. They corrected this very quickly. Later on during sessions this area was only blue.
Webbers t tray looked hot again in quali
n_anirudh
n_anirudh
charlex
-4
Re: R: Red Bull RB9 Renault
n_anirudh wrote:Image
kers cheat failure... jk, dont fire me
via Pius Gassó
Reason: Replaced with our own to make sure it stays online
Hobbs04 wrote:
gandharva wrote: Because it was scraping the ground. Webbers car was set up to low for first stint in FP1. They corrected this very quickly. Later on during sessions this area was only blue.
And in the race. This isn't scraping the t-tray anymore.
DeathDeathDeath
DeathDeathDeath
I've been thinking about these extrusions (Mainly the top one) in the rear of the RB9, and I have a theory.
Do you think that the rear bodywork is somehow slightly flexible, but needs to be entirely rigid in the one area? The top one seems a little too intricate to be merely for cooling, although the bottom one is clearly in a shape which would create a low pressure zone at the exhaust exit.
Cheers,
Death.
The top one splits the airflow to the exit on the side of the gearbox(which sometimes is blocked off) and to the large central exit.
The lower one is not even remotely close to the exhaust and does the same thing as the top one does, only for splitting the airflow between the cooling hole near the gearbox and allowing a bit of air flowing inside the tunnel
Yurasyk
Yurasyk
As RB said it was broken oil radiator that had caused oil leakage and further combustion.
