Red Bull RB9 Renault
flyboy2160
flyboy2160
84
Re: Red Bull RB9 Renault
shelly wrote:
stefan_ wrote:Japan 2013 - Thursday (10.10.2013)
http://i.imgur.com/m4Ne0lB.jpg
-the big fillets at the junction between floor and strakes (other teams do not have them)
RB also fillet the junction of the diffuser strakes and the upper inside surface of the diffuser. As I mentioned in a previous thread, those fillets look like a very thorough attention to aerodynamic principles in even very small details. The junction of two perpendicular surfaces will create what is called 'interference drag,' which can be non-trivial. To overcome this, the junction is filleted, as shown in these photos of the great and beautiful Spitfire. (These metal surfaces, and those in the elliptical wing, however were difficult to fabricate.)
Image and Image
I suspect the exhaust strake filleting also delays the dissipation of the vortices shed by the leading edges.
emmepi27
emmepi27
141
Different cooling solution for Vettel in FP1/FP2
carvetia
carvetia
ebare wrote:As for the paddles, the answer is 'no'. Tech regulations state: "5.5.1 The only means by which the driver may control the engine torque is via a single chassis mounted foot (accelerator) pedal."
Is a pedal still a pedal if it has more than one axis of movement? The interpretation of rules has always been about semantics :D
Japan 2013 - Saturday (12.10.2013)
Huntresa
Huntresa
Is that the famous Magnetti-Marelli alternator ?
H2H
H2H
Huntresa wrote:Is that the famous Magnetti-Marelli alternator ?
Should be the KERS control unit. At least since the RB7 it was always there. :wink:
Juzh
161
RB use mclaren supplied alternators from 2013. Funny how all the problems seem to have vanished since.
Yurasyk
Yurasyk
Juzh wrote:all the problems seem to have vanished
Not all the problems. KERS still exactly works "perfectly" :)
Poleman
stefan_ wrote:Japan 2013 - Friday (11.10.2013)
http://i.imgur.com/2lhknbG.jpg
What's that smoke stream coming out of the cooling outlet?
Smart move, McClaren.... yeah, smart move... :roll:
tony77g
tony77g
36
Vettel and Webber,
Differences Rear Wing in Qualifying
Juzh
161
Kers is a whole other issue.
dxpetrov
dxpetrov
-7
Seems like lower AOA for SV. I thought Webber had set out for higher top speed ?!
rgkma
rgkma
have noticed past couple races that happening on both the RBRs.
csponton
csponton
I think the rear wing to Vettel and Webber is identical. Look at the pictures here: http://f1grandprix.motorionline.com/fot ... ABATO/p-2/
In FP3 wings were different
