Ferrari 150° Italia
hardingfv32
hardingfv32
35
Re: Ferrari 150° Italia
But in this case would you not think that the flow direction and possible changes of direction are well known? There could be a case made for the steering angle of the wheels creating some interesting problems, but this would have been seen in the wind tunnel long ago. Also, this instrument is only good for 45 degrees. We are pretty much still aimed at the track surface.
Brian
thisisatest
thisisatest
i think the tips may bend back to horizontal
kalinka
kalinka
WOW ! It's the MOTHER of all pitot arrays in F1 :)
aral
aral
26
kalinka wrote:WOW ! It's the MOTHER of all pitot arrays in F1 :)
Maybe this is a new multi tier rear wing that they are trying out :lol: :lol: :lol:
Tim.Wright
330
Maybe they are oriented at 90deg to the airflow because they are measuring air speed, not air pressure.
Tim
hardingfv32
hardingfv32
35
I don't know, from what I read yesterday that is not how airplanes measure speed. They do have ports in surfaces that are parallel to air flow. Would a nozzle in the free air stream 90 degrees to the flow function the same as a port?
I have yet to find anything in the literature about using the pitot-tube at 90 degrees to the flow axis.
Brian
Owen.C93
Owen.C93
177
Tim.Wright wrote:Maybe they are oriented at 90deg to the airflow because they are measuring air speed, not air pressure.
Tim
I assumed the opposite, angled down they measure pressure which is not effected by air speed.
imightbewrong
imightbewrong
Hah, wtf! Where is that exhaust pointing?!
Lorenzo_Bandini
Lorenzo_Bandini
I think Ferrari want to know how will be the car without blown diffuser.
MIKEY_!
Wow I'd have thought they'd just move the pipes higher!
Owen.C93
Owen.C93
177
And why just the one side?! Interesting at least.
aleks_ader
90
MIKEY_! wrote:Wow I'd have thought they'd just move the pipes higher!
BUt for that they will need new ekhaust manifold and new cover ($$$$)...
I assume that "solution" for the test they remeber yesterday. Than they quicly improvize and just remove flat outlet and add this curved tube to nevralise EBD efect on the left side...
I wondering to know why is this just on one side... are this colected data relevant? How many laps they do with ths setup?
Hmm interesting will be data from corners speed (expecially focus on similar left and right cornes)?
aleks_ader
90
Forza
238
aleksandergreat wrote:Image
Ferraris exhaust expansion chamber, as reported by Piola
amouzouris
105
What does the exhaust expansion chamber do??
